not seeing enough boost... .6 Bar max :(
Old Dec 1, 2008 | 08:32 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
So finally after getting my CEL and ABS/PSM lights to stop (replaced MAF and wiring harness), my car was running good with no codes for a few days.
Today I run to the bank and hit it hard in 2nd and it pulls just as strong as ever, but didn't check the stock boost guage.
I leave to go home and hammer it again and it feels much much weaker. I switch over to check the boost and hit it again it tops out at .6 Bar in 2nd gear a couple times I tried it.
I did some searches but searching for "low boost" and such didn't net me much for results.
What are you guys thinking?
Blown MAF already? (installed new one on Wed)
Boost leak?
After running flawlessly for 5 months and 8k miles, this thing sure has been giving me fits lately.
thanks
Old Dec 1, 2008 | 08:34 PM
do you have a aftermarket airbox?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 1, 2008 | 08:39 PM
flash68's Avatar
Yes, I have EVOMS stage 2 with V-flow (older version), DVs, GIAC tune, Fabspeed Maxflo exhaust.
Old Dec 1, 2008 | 08:45 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Call or write to Shark Werks
Old Dec 1, 2008 | 08:47 PM
flash68's Avatar
Ha. I probably will talk to him on Friday when I go down there for some suspension stuff, but I wanted to see if there is anything I can do now or at least get an understanding of what I am dealing with or troubleshooting.
Old Dec 1, 2008 | 08:48 PM
disconnect the battery for 10 minutes....
try it again...
9.66
click to view
Old Dec 1, 2008 | 08:49 PM
flash68's Avatar
try it again...
Okay will go try that. Thanks Mark
Old Dec 1, 2008 | 09:05 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
If it is MAF, in first gear it will sputter around 4000-5000rpm, the car will not pull hard. Having low boost is not MAF related. Disconnect the MAF and try it again. Possible: boost leak, hoses?? I have disconnected my MAF on my stage IV before with no problems. I am sure Mark will give his blessing too.
Old Dec 1, 2008 | 10:00 PM
flash68's Avatar
try it again...
Markski saves the day again. I just hit 1.0 Bar that I saw. I have hit 1.1-1.2 before so maybe I just didn't see it. But that sure fixed it.
So.... how the hell did that fix it is what I wanna know... ??
thanks!
Old Dec 1, 2008 | 10:49 PM
soothsayer's Avatar
soothsayer is infamous around these parts
That happened to me the other day in 20 degrees where it would go past .6 . Its the first time thats happened but it felt normal. Is that normal? I was thinking it was because it was freezing out maybe??? Markski? anyone?
Old Dec 1, 2008 | 11:16 PM
when it gets cold the boost goes up so u probably overboosted and the ecu pulled back... and maybe went into limp mode.... it may happen again...
anyone using aftermarket WG springs? if so it can happen more often...
9.66
click to view
Old Dec 1, 2008 | 11:23 PM
flash68's Avatar
Damn, 60 degrees is "cold enough" to overboost? Interesting...
thanks again markski. you are a huge help around here for a lot us!
Old Dec 1, 2008 | 11:35 PM
soothsayer's Avatar
No, I think he was referring to my same issue in 20 degree temp. Either way, thanks Markski for the info.
Old Dec 1, 2008 | 11:54 PM
flash68's Avatar
LOL, good point!
Markski, can you help explain why the battery reset solved whatever issue I was having? I disunderstand....
Old Dec 2, 2008 | 01:07 AM
LOL, good point!
you reset the ecu .... but like I said it may happen again.. you proabbly aboosting close to 1.3 bars just not seeing it on the dash.... and giac flashes protect the car from blowing up.... well they have the stock 1.3 bar safety in tact....
do you have stock wgs?
9.66
click to view
