Ball Bearing turbos vs others
Old Jan 7, 2009 | 04:49 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
What are the advantages and disadvantages of bearing turbos? Are they preferred over non-bearing turbos? Any maintenance issues? Thanks for the info in advance.
Old Jan 7, 2009 | 05:12 PM
ttboost's Avatar
The rage of ball bearing turbos is their ability to spool up faster and stay spooled between shifts and what not. I've had both ball bearing and non ball bearing turbos. IMO and experience, it's all hype. For the additional cost and the fact that ball bearing turbos are supposedly not rebuildable...no thanks.
Old Jan 7, 2009 | 06:59 PM
Dr_jitsu's Avatar
Not rebuildable? W/ Garret/Tials you get a guaranteed new cartridge for $450 for both turbos no matter the cause of failure (that includes labor, everything...send any authorized turbo builder the turbos and 450 and you get essentially new turbos).
Old Jan 7, 2009 | 07:13 PM
MBailey's Avatar
You would probably need a GPS timing device to tell the difference in spool up but if you need every 1/100 for an ET...
The durability of the ball bearing turbos is also greater than non-ball bearing. If you are going to track it alot I would go with ball bearings.
Old Jan 12, 2009 | 01:30 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Advantages of ball-bearing turbos is they are known to spool quicker. They are prefered over non-bb. The only draw back is they cost ~$1k more than non-bb. Also bb turbos need to be watercooled. I believe the set you were looking at was a set of hybrid non-bb.
Old Jan 12, 2009 | 02:51 PM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
less moving parts, stronger, better spool
Old Jan 15, 2009 | 02:59 AM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
so lucky u. u almost lost your $$$ if they were hybrids n non bb jk.
Old Jan 19, 2009 | 12:55 AM
Divexxtreme's Avatar
Thread has been cleaned up. All personal info and off-topic posts have been removed. Please keep it on topic. Thanks.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
turkish1
Nov 11, 2015 09:01 PM
The Oss
Aug 24, 2015 08:19 PM
su_maverick
Aug 21, 2015 07:14 PM
