Boost question for my gt2
Old Jan 29, 2009 | 12:02 AM
Jorgeassoc's Avatar
Jorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant future
Question: When i use to WOT, It use to read 1.4-1.5bar. Now, on WOT, it goes up to 1.1bar. What is the cause ? I recently installed the Cargraphics exhaust loud, and gmg dv's.
thanks in advance for your help.
G
Old Jan 29, 2009 | 12:08 AM
Jorgeassoc's Avatar
Boost leakage ?
Old Jan 29, 2009 | 12:22 AM
boldis_63's Avatar
boldis_63 is infamous around these partsboldis_63 is infamous around these parts
The ECM is tuned right? Cause soo much boost is not stock.
Old Jan 29, 2009 | 04:31 AM
G
Could be a bad install... probably a boost leak...
what exhaust did you have b4? stock?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 29, 2009 | 07:37 AM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
Do you mean that before the exhaust was installed boost made 1.4-1.5 bars and post exhaust installation you can't make peak boost, or was it ok after exhaust install but recently you've noticed a loss? If all was ok after the exhaust and dv installation you probably do have a leakage. What ecu software are you running?
Old Jan 29, 2009 | 08:23 AM
Jorgeassoc's Avatar
Post exhaust install ive noticed that my boost has not been reaching as high as before. And before, my car was bone stock except the GIAC tune.
Where should i check for leakage ?
Markski, maybe now is a good time to go protomotive ?
Old Jan 29, 2009 | 03:37 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
You had a boost pressure of 1,4-1,5 with just a software tune?Something was wrong...maybe you had leakage in wastegate vacuum hoses and turbos were trying to reach desired pressure and overboosting the car...
Old Jan 29, 2009 | 07:30 PM
smooth_operator's Avatar
smooth_operator is infamous around these parts
Who did the work? Are the dv's installed properly and are they adjustable? Can you change the springs?
Old Jan 29, 2009 | 08:48 PM
Dr_jitsu's Avatar
1.5 bars on stock fuel system and pump gas? You are lucky you didn't blow your motor.
Old Jan 30, 2009 | 12:04 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
He's gotta point, I missed it.
Old Jan 30, 2009 | 12:13 AM
art4iza's Avatar
Exhaust not installed correctly. DV's failing. Boost Leak. Need to put on live Dyno I think and check out all hook ups.
Old Jan 31, 2009 | 12:18 PM
Jorgeassoc's Avatar
GMG installed the DV's . I am going to contact them today. Nice to hear from everyone. And thanks for the extra advice/help via pm. Ill get back shortly with a report. peace.
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
