changed alignment settings...vast improvement
Guys,
I have the same Moton/ERP/GT-3 bar suspension that Ken installed on his car. I have been chasing some push in fast sweepers after I get back on the gas hard.
I have been running roughly 1 degree neg. camber in the front and a very small amount of toe-in. Yesterday I had the car realigned to 1.5 degrees neg. camber in the front (the most that the stock adjustment slots would allow) and zero toe. Woe...what a difference. I have not had the opportunity to drive it for any distance in real anger, but it feels much more neutral now.
BTW, the other alignment specs I have are 1.8 degrees neg. camber and 0.36 total toe in the rear. I am running 1 degree of rake as well. The Club Sports are set to 3 bump and 4 rebound and the bars are full stiff in the rear and one hole from full stiff in the front.
Re: changed alignment settings...vast improvement
Glad it's coming together...
Update...the only thing that I have noticed that is not absolutely positive with this setup (and is to be expected) is a very slight dartyness under heavy braking. No big deal...just have to be awake :-))
Is dartyness a word???
If you have zero static toe, then you would probably have
a little induced toe-out under braking, but not much. Toe-out
does cause a little dartiness, and having more negative
camber will lessen your maximum braking a bit because your
tires are less flat on the ground.... Tradeoffs, tradeoffs. We will
have to wait for active suspension to get the best of both...
Joe
Joe
Joe
Joe
Interestingly, Mr. Lieb from Ruf sent me an email a number of months ago in answer to my request for a solution for the push while I still had the Ruf PSS-9 suspension on the car. His specs called for the same 1.5 degrees neg. camber and zero toe in the front. And that was with the rubber donut still in the car.
As an aside, today I softened the Club Sports from 3 bump and 4 rebound to 2 bump and 3 rebound all around. Have not had the opportunity to check things out much...they frown on that during rush hour up here
Jul 29, 2019 11:13 AM
Aug 20, 2015 12:17 PM
