Easy way to RWD temp only
Old Feb 19, 2009 | 05:00 AM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
A group of guys have a dyno day going and I kinda want to go for kicks. Draw back its only rwd/fwd dyno not a AWD dyno. I want to see if my A/F are fine, that is my only concern since i have a flash. Is there a temp easy way to make the car RWD only. Disconnect front drive shaft and thats it ? I probably won't drive it more then 30 miles this way. If so, is there a DIY ?
Also how long does the process take it off/put it on ?
Thanks,
Enrique
Old Feb 19, 2009 | 07:55 AM
smdubovsky's Avatar
smdubovsky is infamous around these parts
Im interested in the answer to this too. Sounds like you only need to pull the driveshaft from what Ive read, but waiting for those who have BTDT.
Old Feb 19, 2009 | 12:33 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
Do a search "rwd conversion"
heres some, there are many more
https://www.6speedonline.com/forums/...996-turbo.html
https://www.6speedonline.com/forums/...d-awesome.html
Old Feb 19, 2009 | 12:35 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Just remove the front to back drive shaft. You can run like that with no issues. I ran that way for over a month.
Old Feb 19, 2009 | 12:42 PM
DNugget991GT3's Avatar
take out the drive shaft
it literally takes about 4-5 minutes...
Old Feb 19, 2009 | 12:59 PM
Al Pettee's Avatar
Al Pettee is a jewel in the roughAl Pettee is a jewel in the roughAl Pettee is a jewel in the roughAl Pettee is a jewel in the rough
Tangential question: Does anyone know what the AWD diff. is rated at being able to handle max. HP/torque-wise on the 996TT? For high HP/torque upgrades, any physical limitations to the AWD diff. above the 800HP/lb-ft level?
Certainly, drivetrain losses increase with the AWD functioning, but with 800+HP, that should counteract some of those losses. The remaining question is would the diff. malfunction transferring some of that higher power and torque to the front wheels?
Old Feb 19, 2009 | 01:06 PM
cjv's Avatar
cjv
Moderator
The 996tt front differencial is weak to say the least. Thedy are far less beefy than the 993tt front differencial. However, very little of the power is actually transfered to the front wheels. Less than 10%. I believe they are rated for about fifty foot pounds of torque.
Old Feb 19, 2009 | 01:10 PM
smdubovsky's Avatar
The center diff is viscous I think. Im not sure it has an inherent limit other then getting too hot. The fluid is whats doing all the work?
Old Feb 19, 2009 | 01:25 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Yep, remove drive shaft. You will need to remove the under trays first, then 3 bolts to unscrew. When you place it on the dyno make sure to put PSM off mode. Good luck. Hope you see a good AFR.
Old Feb 19, 2009 | 05:06 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
ok...so i remove three bolts connectind output of tranny to front drive shaft...is there a way to fully remove the driveshaft?Or should i do this job under the dyno and let the shaft hanging for dyno tuning?
Old Feb 19, 2009 | 07:02 PM
art4iza's Avatar
fully remove the drive shaft, you can always put it back in. PSM off.
Old Mar 31, 2009 | 01:18 PM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
When you remove the driveshaft, do you have to cover up where the driveshaft connects to the tranny so it doesn't get dirty?
Old Mar 31, 2009 | 03:45 PM
art4iza's Avatar
Nope.
Old Mar 31, 2009 | 06:54 PM
heavychevy's Avatar
LOL, Steve, your time estimates are a trip. Didn't you say like 30 or 45 minutes to change plugs? It may take 4-5 minutes to actually get the driveshaft out, but jacking it up, puttin on jack stands or lift, removing all the lower paneling, removing the metal bracket in the middle and then the driveshaft bolts and getting it out takes a bit longer than 4-5 minutes.
Fadi
Aug 17, 2018 05:16 PM
nick49
Jan 26, 2017 01:17 PM
168
Sep 19, 2015 05:03 PM
BLKMGK
Sep 19, 2015 03:51 PM
