Some early problems with my Turbo...
Old May 19, 2009 | 05:06 AM
Rental Metard's Avatar
Rental Metard has a spectacular aura aboutRental Metard has a spectacular aura aboutRental Metard has a spectacular aura about
Exclamation Some early problems with my Turbo...
I picked up a 2001 Turbo with Tiptronic transmission and 70,000 miles a few weeks ago. It passed a PPI from Porsche but I've already had a couple problems (not sure if they are related).
The water temperature sensor doesn't appear to be working properly. After driving for many miles (should be at operating temperature) it will sit on the line between 100 and 180 and I know it should be closer to 180. A few times it has been up to 180 but it's rare. It has come up twice with 'failure indicator'.
Yesterday, on the highway I was going about 70 with cruise control on. I turned off cruise control and immediately got a check engine light which is still on today.
I filled up the coolant reservoir because it was below the minimum line but I didn't have to add very much and both problems remain. Also when driving about 65-70MPH with cruise control on (~2000RPM), my oil pressure sits on the 5 line. I'm not sure if that is normal but it seemed a little high to me.
The car itself seems to be running strong with no smoke, noises, or symptoms. If anyone could point me in the right direction it would be extremely appreciated.
Old May 19, 2009 | 06:33 AM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
Once you blow a check engine light, it will stay on until reset by a tech. You may have fixed your problem already and don't know it. As far as the actual problems, I can't add much. Good luck.
Old May 19, 2009 | 07:28 AM
Any procedure to reset the CEL on my own? I assume disconnecting the battery cable long enough might do it. It definitely still has the water temp issue.
Old May 19, 2009 | 07:45 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Get the Durametric scanner. You need to know what the problems actually are instead of guessing. You can also reste the CEL yourself.Trial and error does not work well on these cars. As fot the fluctuating temp. It may be a bad guage, sender or even a sticking thermostat
Old May 19, 2009 | 07:48 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Get yourself a ODB II reader (my was like $60) and find out what code. You can also reset (clear) the code; but the car will learn from scratch again, however the flash would stay on the ECU (if the car had a flash).
Old May 19, 2009 | 11:20 AM
If I take it to Advance Auto, where can I find the OBDII port to scan?
Old May 19, 2009 | 11:54 AM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
Under the steering wheel, above the fuse box...
If it doesn't get a connection, try holding it in there tighter...
As for CEL, I'd also say you should get the code read...but if it's not feeling different and the car drives well, you can probably disconnect batt and reset ECU...
Old May 19, 2009 | 04:04 PM
I had the code read and reset...
P1411 - Manufacturer Control Auxiliary Emission Controls
Any ideas?
Old May 19, 2009 | 04:19 PM
KPG's Avatar
KPG
Secondary air pump. It is used on startup to pump air into the exhaust to help emissions...
Old May 19, 2009 | 07:31 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
If you're "Porschekid" on Renntech I posted some search links on that forum too...
Old May 20, 2009 | 04:51 AM
Thanks a lot for the scan KPG.
I am, thanks.
Old May 20, 2009 | 12:04 PM
albuht813's Avatar
albuht813 is infamous around these parts
congrats on your purchase. it's not too fun to hear about all these issues, but hope it gets worked out!
Bmw M3 Guy
Feb 21, 2018 09:29 AM
ExSF
Bentley
Apr 9, 2017 05:28 AM
webcarconnection
Sep 21, 2015 10:54 AM
KOCF
Sep 18, 2015 04:02 AM
