DIY Head Light Switch Remove and Replace
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 19, 2010 | 05:48 PM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
good question. from what I recall, just the driving lamps worked- maybe fog but definitely not low or high beams
solution? drive faster during the daytime
Old Oct 19, 2010 | 08:25 PM
911TurboRules's Avatar
911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of911TurboRules has much to be proud of
Mine just plain didn't turn on (no lights - all or nothing). It was intermittent. Sometimes it would work if I turn the car off and turn it back on a few times. At least it's a cheap part ->
http://www.suncoastparts.com/category/996ttelect.html
Good luck.
Paul
Old Oct 19, 2010 | 10:09 PM
2001Porsche911's Avatar
2001Porsche911 is infamous around these parts
Thanks everyone!
Old May 7, 2011 | 03:26 PM
spanoulis's Avatar
spanoulis is infamous around these parts
Thumbs up Excellent Post
This was an excellent post with great pics. Wish I could thank you personally and buy you a cold one.
My car failed inspection for headlights. Of course the dealership wanted $330 to replace the headlight switch. I was intent on replacing it myself and was set on buying a new one, dropping a hundred bucks and calling it a day, but then read about using MAF cleaner to clean the terminals. Well it worked for mine too, so thank you! Now I can take it back for inspection and finally get back to driving it. Its a garage queen, but now that the weather's nice here its top down season. I owe you guys!
Old Jun 4, 2011 | 10:00 PM
x50plt's Avatar
x50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to beholdx50plt is a splendid one to behold
diy
thanks for the great write up, start to finish 15 min.
Old Aug 4, 2011 | 11:24 AM
PhatchitC4s's Avatar
PhatchitC4s is infamous around these parts
I just bought a 2004 C4s and i noticed that my passanger headlight is haveing problems. I took it out and tried resitting it and it wroked for a few days (at least i think it did) but now its back to me moving the switch to the on and off position to get it to come on. Is this a problem with the switch or is it a problem with the ballast.If anyone can help me out i would love it . Sorry to post on a old thread.Peace!
Old Aug 5, 2011 | 07:49 PM
kelvintak's Avatar
kelvintak is infamous around these parts
thanks so much it's useful and clear
Old Aug 9, 2011 | 05:46 PM
smistry007's Avatar
if it's just one side, it's probably the light itself- try a little sandpaper on the metal electrical connections- they may be corroded.
if it's both lights simulataneously, it's probably the switch.
Old Nov 11, 2011 | 03:08 PM
Matthiew's Avatar
Matthiew is infamous around these parts
cleaning question
Those of you who've cleaned with fluid, do you still do the entire disassembly illustrated in the post. This site is an amazing resource. Thanks for your replies.
M
2003 996 Targa with the very beginning of this problem. She is 8 and precotious so I really can't scold her.
Old Nov 14, 2011 | 09:57 AM
ait109's Avatar
ait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant futureait109 has a brilliant future
Yes. The actual switch is the silver+red thingy in photos 6 and 7. Once it is removed it is pretty easy to clean.
Ed
M
Old Nov 14, 2011 | 10:11 AM
Matthiew's Avatar
Ed,
Thanks very much.
M
Old Dec 15, 2011 | 12:14 AM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Easy DIY. Thank you for the photos and instructions. BTW the nut is 24mm.
Old Dec 15, 2011 | 04:23 AM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
Not sure I ever remembered to say thank you. Worked perfectly!
Old Dec 31, 2011 | 07:49 AM
randomquickness's Avatar
randomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to behold
could those who've cleaned with MAF post a pic showing exactly where to spray? My switch is starting to act up and I have a can of MAF cleaner in the garage.
Old Dec 31, 2011 | 08:04 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Just a note about step #7. You do not need to pry the plastic bezel off with a metal tool. That will scratch the plastic and could leave pry marks. You can easily use two fingers and pull it off from the inside it does not clip in.. just kinda sticks in there.
- David
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
