HELP: Advice for Trailering my 996TT
Old Jul 30, 2009 | 08:37 PM
JC919's Avatar
JC919 is just really niceJC919 is just really niceJC919 is just really niceJC919 is just really niceJC919 is just really nice
Hey guys I am wondering if any one has any advice for trailering a 996 Turbo. I’ll be trailering my 996TT from my home in Houston, TX to Santa Fe, NM and I'm just wondering if there are any tips as to where I should connect tie downs to the vehicle. As of right now I’m renting a Uhaul trailer and will be using my Dad’s Denali to do the towing. I've seen a few other threads discussing how a GT3 can be correctly secured, but couldn't find any for the Turbo.
Thanks in advance, JC.
Old Jul 30, 2009 | 08:42 PM
GT3 Chuck's Avatar
Administrator
just one...don't leave it in gear...put it in neutral and use the e-brake...you should be able to get tire cinches and snug down all four wheels...that will hold it
Old Jul 30, 2009 | 09:12 PM
JC919's Avatar
Cinching down the 4 wheels won't mess with the alignment at all? I've seen some connecting brackets mounted on the bottom of 7.1 GT3s and I'm wondering if these are necessary for my car.
Old Jul 30, 2009 | 09:15 PM
heavychevy's Avatar
I've done it through the wheels every time and it's never messed with an alignment one bit. Otherwise you can buy the things that screw into the jack points and use those to tie down. I forget who sells them.
Don't think there is any other option.
Old Jul 30, 2009 | 09:23 PM
996twin_sc's Avatar
996twin_sc is infamous around these parts
I used a uhaul before with no issues. Just make sure the trailer tires have the correct PSI and add some PSI to your tow vehicle (rear tires). I tied down all four wheels to the trailer with zero alignment issues.
Old Jul 30, 2009 | 11:35 PM
SPECOPSCPT's Avatar
SPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant futureSPECOPSCPT has a brilliant future
Better safe than sorry
Better safe than sorry, clinching all four wheels seems like a great idea.
Old Jul 31, 2009 | 07:08 AM
DJM's Avatar
DJM
DJM is just really niceDJM is just really niceDJM is just really niceDJM is just really nice
check this thread out, I just pulled my car 3600 miles, I didnt but any painters tape on the windshield and I got a rock chip and when I backed the car off the trailer the car flexed enough that the windshield cracked, so if I were to do it again I would cover the windshield. https://www.6speedonline.com/forums/...r-trailer.html Hopefully this helps.
Old Jul 31, 2009 | 07:22 AM
DJM's Avatar
DJM
Here is a pic of a blown tire and another one at the north rim of the grand canyon.
Old Jul 31, 2009 | 10:07 AM
WOODTSTER's Avatar
Purchase brand new straps (dont ask me how I know).
Minimum 2" wide (3300 lbs capacity each).
Use a minimum of 4 straps and go in X patter.
from behind the car go in front of rear wheels to hole in subframe at jacking point
from in front of car go behind front wheels to hole in subframe at jacking point
Do a fifth strap if possible around (1) wheel.
This works for all 996/997 cars including cup cars.
Make SURE you have several wraps of strap around the ratchet loop which gives it
its holding power.
You can buy Spray on protection for front of car and mirrors, otherwise 3M painters tape with Duct tape over the painters tape.
Good luck
Marty
Old Jul 31, 2009 | 10:54 AM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
This is a very helpful thread. I'm thinking of towing my car up to Washington in a few weeks.
Old Jul 31, 2009 | 06:45 PM
JonB's Avatar
JonB has a spectacular aura aboutJonB has a spectacular aura aboutJonB has a spectacular aura about
I bought these tie down hooks from Autometrics Motorsports for $80.
They work great.
http://www.autometricsmotorsports.com/index.htm
Fadi
Aug 17, 2018 05:16 PM
RossoDiamante
Track & Autocross
Sep 21, 2015 01:28 PM
Aniel
Sep 13, 2015 08:10 PM
saiko88
Sep 11, 2015 02:17 PM
Zmydust
Sep 7, 2015 01:43 PM
