Tranny Update...
Old Oct 7, 2009 | 11:40 AM
landjet's Avatar
Mike I'll bet you're over paying for the tranny. Eddie Murphy got one for $150.
Old Oct 7, 2009 | 05:38 PM
Mikelly's Avatar
Based on the wear and tear of the parts, I'm still on the fence over steel syncros. We're tossing it around. Christopher was kind enough to send me his mainshaft and parts, so that's that... I think new OEM shafts are running somewhere in the $1500 range. We are indeed doing an LSD.
The Fulcrom is already modified on the pressure plate that I bought from Clutchmasters and other than swapping the kevlar on the flywheel side of the clutch disc, I'm not changing the clutch configuration. It has held just fine over the last 18 months of heavy use in road course and street use.
I'm using the Steel Porsche 964RS OEM flywheel, which we've been using with this setup as well...This packaged is what I have been using and under close inspection of the components, all appears well and I have zero issues with the existing clutch/PP/FW provided by Clutchmasters, and under direct guidance from Kevin at UMW to my Indy, Lufteknic.
Mike
Originally Posted by OS Inspector
just for sake of knowledge what is the part cost of the main shaft and 1st n 2nd gear sets stock and different gearing?
are you doing brass or steel synchros?
LSD?
from some previous custom clutch design and pioneering i have in my past i think you will be happy with fibertuff on your clutch disk
it wouldn't hurt to have some clutch fulcrom (clamping force) discussions and maybe get you a bit more holding pressure so your not in the clutch again next season. what flywheel are you going to be usging ? steel/aluminum?
Old Oct 7, 2009 | 08:17 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
what lsd are you looking at carbonetic ? guards? 50/80? 60/40?
Old Oct 8, 2009 | 04:06 AM
Mikelly's Avatar
Not sure yet. There is discussion about going RWD, which could impact that choice!
Mike
Old Oct 8, 2009 | 12:36 PM
Mikelly's Avatar
Larry, I was gonna break into a Dave chappelle skit, but it's a ***** on the iPhone!!!
http://www.youtube.com/watch?v=D6Yplww55ao
Mike
Old Oct 15, 2009 | 12:00 AM
otb996's Avatar
otb996 is infamous around these partsotb996 is infamous around these parts
Originally Posted by Mikelly
Yea, Larry, I think it was the wife seeing me go off track in the miata one to many times... She was like "I feel so much better about you in the turbo. It's a safer car!"
I'm sitting there laughing, thinking I'm never hitting 170MPH on the back straight at VIR in the Miata!
Mike
Best quote I've read in awhile... maybe if you took the wife for a ride she would understand!
Old Oct 15, 2009 | 08:10 AM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
Mike, main shaft and gears are in the mail, should be at your indy by end of week I'd imagine. Are you doing the GT2 master/slave conversion?
Btw, I am using the steel synchros, dont have enough miles to determine any differences, but I'm digging the 1st-3rd gear changes.
Old Oct 15, 2009 | 03:48 PM
Mikelly's Avatar
Christopher, Thanks Man!!! I'm using the GT2 Conversion from Evoms for sure. We haven't ruled out the steel synchros at this point!
Mike
Rguy
Apr 12, 2020 11:11 PM
Brooklyn boosting
Sep 16, 2015 10:05 AM
Abuong01
930 Turbo
Sep 15, 2015 01:05 PM
MtnTempo
Sep 14, 2015 06:49 AM
Saint Ari
Sep 4, 2015 03:30 PM
