links on how to DIY LSD?
Old Oct 1, 2009 | 09:49 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
Can't find any online. Looking through the 996tt workshop manual, can't find anything accept in the GT2 section. This probably applies but want more info if possible. thanks!
Old Oct 1, 2009 | 11:45 AM
VAGscum's Avatar
Correct me if I am wrong, but I think the reason for that is the 996TT didn't come with a true LSD. The GT2 did though. The GT2 should be the same procedure, but I think there is some setup/shimming required to do it right.
Old Oct 1, 2009 | 03:42 PM
sweeney186's Avatar
sweeney186 is infamous around these parts
Its not an easy job,did my own but auto repair is what I do for a living . Lucked out on reshimming-all in spec w/ the old shims.Very tedious to get it right otherwise.If you don't have alot of exp. w/ setting up ring & pinions its prob. best left to a professional
Old Oct 1, 2009 | 11:18 PM
Mad Ness's Avatar
yes the 996 doesn't have an LSD but didn't find manual instructions on removal/refitting a differential either. GT2 one probably applies but there's not much detail.The manual has about 9 lines of instructions removal/install and no mention of shims.
I'll have a professional helping me, so just need to make sure I've got all the parts/bits ready.
Can anyone shed more light here please? thanks
Old Oct 2, 2009 | 03:37 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
+1 thanks
Old Oct 2, 2009 | 10:08 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Not sure how much speed shops charge to put one in on a porsche but I know on other cars is not that much for labor.
When you consider how much these units cost and a risk of putting it in wrong and ending up with a noisy dif or at the worst a bucket of useless parts and a cracked case, I'd let someone do it whoo's done many on pcars.
Old Oct 3, 2009 | 05:11 AM
Mad Ness's Avatar
your concerns are valid and I agree. my tuner is a very seasoned proffesional and has a relationship with a reputable Pshop if needed. Just doing as much homework as I can on my end. Much of my enjoyment in modifying cars is from the joy of being hands on, which I do not get by simply dropping the car off and paying the bill.
Old Oct 3, 2009 | 07:48 PM
adam699's Avatar
I'm with you on the hands on thing, however putting a diff in has a big potential for disaster and to do it right the first time, you either have to be lucky or very experianced. You also have to consider that the ring and pinion you're gonna be using is not only a matched pair but also a pair that was worn in together, unless you'll be changing that too. If money is no object I'd say go for it and do a writeup
Old Nov 8, 2016 | 07:12 AM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
I have done a couple of Ford 8.8 ring and pinion setups; would the procedure be similar (for those that have done it)? Thanks.
Old Nov 8, 2016 | 08:55 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
I've set up several Ford/Chevy rears back when I was young and drag racing muscle cars with my high school buddies.... It is the same principle, but the application of the process is a little different due to the equipment differences (there isn't a center section in these cars, the diff is housed in the transaxle, and you remove it from the side vs from the back). I'm going to drop my trans myself and take it to a shop that has experience with Porsche transaxle and this sort of job... For the amount it costs in parts to repair if I were to try it on my own and mess it up, I'd rather not take the risk.
Good luck... let me know how it goes for you.
Old Nov 8, 2016 | 09:54 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Myclue
17
May 19, 2016 11:14 AM
NRoy7
Sep 19, 2015 06:59 AM
Saint Ari
Sep 8, 2015 08:47 PM
Saint Ari
Sep 7, 2015 07:09 PM
