TiAL Alpha 30r’s – Stock motor race gas results!
jags, anyone that knows anything knows of your vendetta against Kevin, you take every opportunity to attack him and your thinly veiled attempt here is as clear as crystal. There is considerable info I know and I do know about you
In respect to Tom, and KPG I will stop here, as I do not want to open any cans like you are attempting to do. trust me not a place you want to go.
Jag
OP..sorry for the OT.
Great work Tony and Dave @ EPL. Amazing results.
I love how some justify to themselves their very expensive motor build when others put out huge numbers without it. And yeah yeah yeah it is piece of mind and all that, but we all know how expensive it is to R&R and build the internals with upgrades. If you don't necessarily need it, why do it?
Quality bolt-ons, a good set of turbos, meth/water injection and a good tune is about as far as I'll go. A set up like that in the right car with the right driver will hit 4-second 60-130's and go 200+ in standing mile. What more could you ask for?
I previously had a very expensive and very well-built motor in my P-car...but you know what? My next P-car will retain the stock bottom end. I won't open that motor up. I simply see no reason to these days.
It's absolutely possible.
I likewise share the same opinion as Scott that my next P car will have a stock block...
2001 996TT 3.6L and stock ECU
Our engine has 66k miles on it, beat to hell. We've done some things to it that we thought would blow it, including anti-lagging 1.65 bar. So far so good, just a matter of running a great tune, and always having MS109 or C16 in the tank when you're going to beat on it. Until I see something different I'll hold similar ideas.
It's great to see properly setup cars running with stock based turbos running the same if not better times than those cars with huge turbos. I'm sure as time goes on we will see a bit more of this, especially with better tuning and additional advancements in fueling and engine management.
As to this motor specifically, since it seemed to choke, could we get details on intercoolers and intake piping at least? Stock intake piping would explain much! 83lb injectors at 5bar should be close to 100lb injectors yes? 700WHP should have been doable IMO, this too confuses me! A/F? Were the injectors flowed? System voltage good? Full fuel pressure? Seems off for some reason. Seeking info guys, not trying to throw rocks...
P.S. Why in the world "build" a motor and not do any headwork? Cams at least? If you've got it that far down kripes do something to help it breathe!
P.P.S. I too am happy to see more power being made on stock blocks. I came from the Supra community and 700HP at the wheels was about where the stock cams seemed to be a restriction and a cam swap would safely get you 100more HP. No one worried about the shortblock much until you began hitting 900RWHP and then it was mostly the main caps as I understood it. This was on race gas. That was NOT always the case in that community! We got there slowly. So, I was pretty shocked to hear people in this community, on bigger 3.6l motors, fretting at the 600WHP mark. What is it about these motors that is so fragile exactly? Why exactly does anyone think 700WHP is hurting the motor and what are you sweating? Poor bearings? Rods? Pistons? These motors are a good bit bigger than the Supra, 600HP on good PUMP gas and decent turbos should NOT be scary if the motors have good rods\pistons. I am very happy to see folks like Titan, BoostLogic, and Justinn (others too) willing to push the stock motors more! Now, someone let me into the ECU please.... Okay one last thing after reading all this, run it rich and be safe, lean is not THAT much more power. Timing is where you find power - octane is your friend, detonation is most certainly NOT.
Nobody is trying to justify anything, if want to crank you car up so be it.. there's been plenty of cars that have gone boom & some haven't. I built my car for myself, I do many track days & wanted the security.. If you crank your car up once in a while maybe you don't need a motor build to each is own...so why promote something "stock motor look" what does that mean exactly...it's not pushed? what? It can go faster? what?
Ben has a stock motor...all I gave him was praise on how great his car runs..If you put great number up regardless of internals great!
It's about the willingness and need to do internals up front? Why not push it as far as you can until a rod bends? Not saying you want that, but why do it up front (big $$$) when you don't necessarily have to? I can't speak for you or others, I prefer not to spend money until I have to.
just because you can, doesn't mean you should. I think a setup like this is pushing it on stock internals. There is no doubt that this kind of power will shorten the lifespan of these motors. You don't believe it? talk to tuners that have built engines, talk to Evoms, UMW, Proto. I am sure they have learned how much power these stock motors can take before they let go. It's one thing be a tuner, but it's a whole other thing to be a tuner and engine builder and you see what to much power does to an engine.
I have sa stock motor and I am limiting myself to what my tuner feels is the max power the motor can handle, which is no where near this amount of power. Can I go up to that. Yes, easily, but do I want to bend rods? no. If I can eventually do an engine build then I will go for bigger power, but until then I'd rather be safe.
but hey it's your engine.
the old saying, "if you wanna play you gotta pay" is so true here.
I would edit your old saying to now read:
"if you wanna play, you can still do it safely but now for less money"
Dammit Jake, that is no help!
I know my old 96lb injectors on my Supra were running out of fuel somewhere between 850whp and 950whp depending on the type of fuel used. C16 and Q16 took different amounts of fuel to make the power in that range and the injectors were about tapped out. The base pressure was around 40psi.
So depending on the base pressure in this car, I can see them running out in the 700-800whp range. I know Porsche uses a different regulator but this was a stock regulator?
