Boost Leak?
Old Oct 27, 2009 | 11:00 AM
cybersam69's Avatar
cybersam69 is infamous around these partscybersam69 is infamous around these parts
Boost Leak?
Turbos seem to be sputtering after .6 or .7 bar. CEL will also flash, they stay solid. Only when you really give it the beans. Seems like if you wind up to it slowly, they're fine. Can't hit 1.0 anymore. Thinking some sort of pressure leak. Any thoughts?
Old Oct 27, 2009 | 11:10 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
I had exactly these symptoms two weeks ago. I had a boost leak at the passenger side intercooler/hose connection AND a bad plug/coil pack. You need to pressure test for the boost leak, and check the code for the misfire.
Jon
Old Oct 27, 2009 | 11:43 AM
cybersam69's Avatar
Just did some searching, lots of people are thinking this is plugs.
Old Oct 27, 2009 | 11:50 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i had a similar problem but wasnt getting any cel's, my guy replaced the plugs and coils and that fixed it
seems to be fairly common, i posted here when i had my problem and a bunch of people said it was plugs
Old Oct 27, 2009 | 02:16 PM
vividracing's Avatar
Plugs plugs plugs. Put some Denso IK22 iridiums in there and you will be good.
Old Oct 27, 2009 | 03:28 PM
FAST FWD's Avatar
You have a CEL! For goodness sake, read the codes before you start buying and replacing parts.
As I and others have said, it is very likely plugs and/or coil packs. The labor to replace plugs is significant. I would recommend doing coil packs at the same time.
Old Oct 27, 2009 | 03:30 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
It could be plugs, DV's, MAF (less likely if its stock), loose hoses....read the codes YES
Old Oct 27, 2009 | 05:10 PM
buzzm's Avatar
its not stock, he has exhaust, dv's and a tune, is it worth removing the maf and taking it for a quick ride to see if the problem persists ?
Old Oct 27, 2009 | 05:29 PM
cybersam69's Avatar
The car is in good hands. I'll be leaving it with my mechanic later this week as I will be out of the US all of next week. They'll have plenty of time to work it out.
I'll keep everyone posted.
awesomebang
Jul 5, 2017 08:48 PM
COBB Tuning
Jan 5, 2016 07:06 AM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
