Cold Engine Rev - Good or Bad for Turbo Car?
Old Jan 17, 2010 | 04:27 PM
GoingFast's Avatar
GoingFast is infamous around these parts
I told my friend that he should not rev his turbo car when it has been sitting in storage for 2 months and he just revved up the engine when he cold started to reshuffle his cars in his garage. In general, it is not good to rev engine when it is not totally warm up, correct? And more damaging for a turbo? Sorry if this is a stupid question. If you don't ask stupid question, you are definitely going to repeat the same stupid mistake over again over again.
Thanks for reading,
TC
Old Jan 17, 2010 | 04:33 PM
GT3 Chuck's Avatar
Administrator
not good for any engine
Old Jan 17, 2010 | 04:42 PM
Schwabe's Avatar
Schwabe has a spectacular aura aboutSchwabe has a spectacular aura aboutSchwabe has a spectacular aura about
+1 not good, oil has a much different viscosity when it is not at working temp. Oil film might break and you lose lubrication.
Old Jan 17, 2010 | 04:48 PM
GoingFast's Avatar
Thanks Chuck and Schwabe! I will try to convenience him with the viscosity explanation.
Old Jan 17, 2010 | 04:53 PM
Patrnflyr's Avatar
Patrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant futurePatrnflyr has a brilliant future
As a newbie, I agree with these answers and can give you another story. I'm a pilot and the general aviation planes that I'm around with turbos REQUIRE the oil temp to be up before even moving out of idle. They also REQUIRE letting the plane sit at idle after landing for approximately 3-5 minutes to let everything settle down before turning it off. Hope this helps
Old Jan 17, 2010 | 04:59 PM
ttboost's Avatar
Porsche recommends that you start the car and drive right away, don't let it sit and warm up. It will warm up faster driving it. Do NOT build any boost until you are up to temp. When shutting the car down, most, if not ALL engine builders and vendors here, will tell you to let it idle for 2 minutes before you shut it down. Not 1-1/2 minutes, 2 minutes.
Old Jan 17, 2010 | 05:10 PM
GoingFast's Avatar
This is my bible when I start and shut down my car.
Old Jan 17, 2010 | 05:45 PM
oatmealadam's Avatar
oatmealadam is infamous around these parts
I drive in colder climate here as well, but I always let the car sit at idle for at least 1 minute and begin driving keeping gear changes under 3000RPM until the car is fully warm. It only takes about 2-3km of easy driving and it's warm. I know any turbo should have a brief cool down and I thought it had something to do with the turbos vanes from having heat warping after a rapid shut down???
Old Jan 17, 2010 | 06:05 PM
BlueFVD-575's Avatar
BlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to beholdBlueFVD-575 is a splendid one to behold
I also have some questions about cold starting after a 2 week sit...
I like to take it out every 2 weeks or so in the cold if the streets are dry.
Engine turns over once, then pauses, then fires up every time. I let it idle for 2-3 minutes until the revs settle to 1000-1100, then drive gently until engine temp is up, then get more aggressive from there. Is this ok or should i just let it sit till march?
Old Jan 17, 2010 | 06:14 PM
911 RV's Avatar
911 RV is infamous around these parts
If you are running GT style turbos with water cooling at the journals, would it not then be nesisary for the 2 minute cool down.
Old Jan 17, 2010 | 06:20 PM
ttboost's Avatar
The "cool down" for turbos is to prevent "coking" of the turbos, which is the oil baking on the inside of the turbos which are still very hot, even with the water.
Old Jan 17, 2010 | 06:43 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
I believe Porsche has other things in mind with regard to the recommendation. I think they first and foremost put that information in the owner's manual to satisfy the "Green" movement in Germany...idle warm up believed not to be "green" at all. I think Porsche's other reason was based on protecting the transmission. Although not an entirely safe bet by Porsche, I think they are betting that the chances of an owner starting up and immediately engaging in "hard" driving is pretty low. So by driving off right after a cold start, and taking it easy for awhile after doing so, the transmission will have a chance to warm up before the owner hammers the drive train (and engine). I think some drivers forget about warming up the transmission.
I personally idle warm my engine a bit before driving, and once I start on my way I keep the RMP below ~3000 with no hard pulls until the engine oil and transmission are warmed up.
Old Jan 17, 2010 | 06:53 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
Thanks for reading,
TC
WTF, call me during the week and we'll go and confiscate his car
Old Jan 17, 2010 | 06:57 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
years ago when i had a collection , if a car sat for even two months i pulled the plugs and prelubed the cyclinders. i do rember i left a car for a year or so ,i prelubed stated it and gas leaked everywhere (very scary) anyway no fire but i learned my lession when things are left alone they wear out all by themselves gasket get dry and opps your leakin oh shi. forgot to use caps Again
Old Jan 17, 2010 | 07:39 PM
DNugget991GT3's Avatar
i turn my car on, immediately pull out of my driveway while the car still is in cold start
(idling very loud at 1200 rpm)
i then proceed to drive down 1 block, engage in a controlled powerslide and red line first and 2nd gear while getting onto the expressway
have been doing this for 2 years now
ive never warmed up any of the cars ive ever owned
its all a myth
