New cylinder head question
Old Dec 18, 2004 | 02:35 PM
gobie18's Avatar
gobie18 is infamous around these parts
Hi
My car is at the dealer right now getting the right side cyclinder head replaced because there was a small crack leaking coolant. Is there anything to look for after a head replacement? I'm just kind of worried that the car will not be the same bacause both side are now not even. Has anybody had this problem before with their TT. Should there be anything I need to look for after I get the car back.
Gobie
2002 TT
Old Dec 18, 2004 | 04:29 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
There should't be any problems if the dealer installs it correctly. It's a pretty easy install, so it's hard to believe they could screw it up. They will perform a compression test and a leakdown test to make sure that all componants and seals are right.
Old Dec 19, 2004 | 06:52 AM
jayster's Avatar
jayster is infamous around these parts
Cool heads up
Hi, the dealer will probably drop the engine ( I hope so ) to rnr the head. The leak you describe sounds like an external leak. Anyway coolant in your oil is sort of obvious, when they drain the oil it will look like oil or a milk shake. So mention this to them, and talk to the tech if they will allow you to do so. As well, Porsche holds very tight tolerances, so differences from side to side, isnt much of a problem, and timming the cam is fool proof (almost, aargh!), they use "fixtures" similar to hydraulic 993 engines.
Your concerns are founded, also there are plenty of qualified techs, just make sure you got one on the job. Talk to your advisor and the tech until you are satisfied with them, or find another dealer. Hope this helps.
Old Mar 28, 2011 | 12:01 AM
msalamza's Avatar
msalamza is infamous around these parts
Cylinder crack
Hey guys, I have a 2001 c4, and porsche said that there is coolant/moisture in cylinder 1 and possibly 5. There is not any oil in the coolant, but i think there might be coolant in the oil because I drained the oil myself and it was very thick and black. I couldnt get all the oil out and most of the oil is stuck in there because its so thick Also the engine light is on and flashes on startup sometimes. Any idea what the problem is? I am thinking about fixing a cylinder head crack. But im not sure. any help would be great thanks!
Old Mar 30, 2011 | 04:37 PM
jayster's Avatar
Hi
water in the oil would look "milkshake" like, ala 944.
How did they make this determination? Wet plugs?
I could use a little more info on this.
Jay Putnam.
Old Apr 24, 2011 | 03:29 AM
msalamza's Avatar
Thanks for the response jayster and forgive the delay. I drained the oil myself recently. it was very thick but that could be because the car was sitting in cold weather for a few days. The oil was black and I was not able to get it all out because it was so thick. I only got about half of it out. And porsche said that they found signs of coolant in cylinder 1 and 5. I don't want to sound desperate but I have been struggling with this problem for years. And I need your input. Thanks.
Old Apr 24, 2011 | 10:40 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Motor has to be dropped to remove a cylinder head in these cars as the cams have to be removed to get at the head studs so 90% of the motor has to be disassembled for that to happen.
there has been some reportings of bad castings leaking coolant that is why they are changing the head i assume.
Old Apr 25, 2011 | 02:02 AM
msalamza's Avatar
So is it worthit to drop the engine and remove the heads? or is it better to just swap the engine?
Old Apr 25, 2011 | 02:39 AM
most dealers just put ina new engine and sent the old back to Porsche.
Old Apr 25, 2011 | 01:49 PM
msalamza's Avatar
I don't want to take it to the dealer. Is it worthit to put in a used engine? or is it better to fix the heads?
Old Jul 12, 2011 | 02:41 AM
msalamza's Avatar
UPDATE***** I took my 2001 C4 to the mechanic and he dropped the engine and took it apart. He found a small crack in cylinder 1. Does anyone know if it is worthit to fix a crack in the cylinder wall? Any advice would be great! thanks!
I also have pictures of the cracked cylinder if needed... thanks again!
Old Jul 12, 2011 | 05:48 PM
jayster's Avatar
Normal or Turbo?
jayster's Avatar
Pic plz
Old Jul 14, 2011 | 04:12 PM
msalamza's Avatar
its a normal 2001 911 c4. here is the pic. Any idea whats the fix?
Old Jul 14, 2011 | 04:13 PM
msalamza's Avatar
