Question re. Boost Leaks
Old Jan 31, 2005 | 09:24 AM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
Question Question re. Boost Leaks
There have been quite a few posts regarding the power loss from boost leaks. I was wondering, if to fix them the motor has to be dropped, if not can someone post the list of the boost hoses to check and can it be done in one's garage. I would assume that if there is a boost leak then you would see lower peak boost levels on the gauge. Is this assumption correct even if the leak is small?
Old Jan 31, 2005 | 10:01 AM
jayster's Avatar
jayster is infamous around these parts
Lightbulb boostage leakage
It would depend on where the boost leaks are, but none of them are small.
The area's you could check are at the diverters, possibly a loose hose clamp. Especially if the diverters were replaced, and the stock clamps were not reused. Also you could have an internal failure of the diverters. The other area you may be able to do some thing about is the "innies" and "outies" (over simplification, I'm afraid..) boost hoses. Check the two big black hoses in the engine ("outies") compartment by pulling and wiggling at the same time, neither should yield on either end of the hose. The other ("innies") are under the car, just underneath those cool exit ducts in your rear bumper, reach under and do the wiggle and pull routine for both hoses, one each side. If these 4 hoses and your diverters are tight, then you should seek professional help.
Jay Putnam
Old Jan 31, 2005 | 10:45 AM
Sean's Avatar
Sean is infamous around these parts
Re: Question re. Boost Leaks
bruce....i also have r-turbo and expereiced the same a few months ago. it was a simple problem and easily diagnosed/fixed....see attached thread:
https://www.6speedonline.com/forums/...&highlight=ruf
if you'd like to discuss offline, feel free to pm me.
Old Jan 31, 2005 | 12:06 PM
ebaker's Avatar
ebaker is infamous around these parts
Sean, how did the RUF tech find the leak?
Old Jan 31, 2005 | 12:57 PM
schnellerm3's Avatar
schnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant future
To find boost leaks, you simply do a pressure check - is there an accessible intake track on the Turbo? AWE sells a piece of my car that you affix to the intake pipe right after the MAF, with a fitting for an air compressor. You can see if pressure is leaking from the system (my shop pressure checks at around 20psi). If you have a breather in the intake track for the differential or anything like that, be sure to plug it off (but, a shop should also know to do that).
If you have trouble finding the leak once you know you have one, you can actually fill the system with smoke from a fog machine, and then pressure check and look for the smoke leaking out.
Old Jan 31, 2005 | 01:55 PM
Orli930's Avatar
Orli930 is infamous around these parts
You need to pressure check the motor, in my car the hose where the DV's mount (F-HOSE) were leaking and I needed to be replaced and the plenum was not mounted correctly. To fix both they needed to partial drop my motor.
Old Jan 31, 2005 | 02:09 PM
ColorChange's Avatar
ColorChange is infamous around these parts
I had a leak and used EVO's new hose kit. Problem solved.
Old Jan 31, 2005 | 04:16 PM
Sean's Avatar
ebaker....christian, tech who came over from ruf to assess cause, had a homemade contraption of sorts to detect the leak...it was detected in about 5 minutes.
Old Feb 1, 2005 | 05:40 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
As someone said, start with simple. My car developed a boost leak all of a sudden about a year or so ago. Porsche dealer after charging for diagnostics told me they didn't find anything (visual and clamp tests supposedly, never use South Shore in Freeport BTW) and 2 days later an independent mechanic working in my own garage found loose clamp right on top of engine out back. Porsche uses these crappy compression type clamps and when we replaced with screw type problem was fixed and boost was .1 better than before. Frankly. I'm asshamed I didn't find it myself.
Old Feb 1, 2005 | 08:03 AM
Bruce's Avatar
Member
Thanks guys, I'll check the hoses that are easily reached and go from there. Like Sean my boost was running consistently at 1.2 bar max. and now it's 1.1 and takes considerably longer to reach where before it jumped right to 1.2 bar. Sean, I'll PM you.
Jul 29, 2019 11:13 AM
markski@markskituning
Aug 24, 2015 10:07 AM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
magoochi
Aug 23, 2015 05:54 PM
