K24
Old Jul 5, 2010 | 03:04 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
K24
should I switch to K24, the difference will be very "dramatic"? i know that maybe 50hp more, I really don't know what to do...
if i will take them to a good price maybe i will buy them but then what should i change again or what to add?!
Old Jul 5, 2010 | 03:10 PM
XLR82XS's Avatar
What is your current setup? A K24/18g setup with 5 bar & I/Cs will be a rocket.
Old Jul 5, 2010 | 03:14 PM
unvmy996's Avatar
indeed i would just do the 18g setup , might as well since your upgrading.
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Alex - IMO, it really depends on what you are trying to accomplish. Raw hp isn't the only thing that counts. When and how it comes on is very important.
When I was planning my upgrades, I spoke with several of the tuners here, and chose UMW because I thought Kevin's kit best suited my needs. We discussed how I use the car (DE's on road courses), and my tolerance for risk. I'd suggest that you do the same, that is talk to several tuners and see what package best suits your needs.
Good luck,
Jon
Old Jul 5, 2010 | 03:22 PM
RudyTT's Avatar
RudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to behold
Go with hybrid turbos (be it K24/18, some sort of k16 variant, etc.) if you are going to upgrade turbos. I don't think the labor costs involved with going from k16 to k24s and the costs associated with re-flashing your ECU justifies the ~50hp gain.
Old Jul 5, 2010 | 04:11 PM
getting k24s is worthless... unless you upgrade them to 18gs, maybe port and polish with a clipped turbine wheel.. add 1 bar Wg springs,5 bar FPR, EBC and your flying... run 1.15 bar on pump and 1.35 on 100 or 104... then if your really interested do some good replacement ICs, injectors, good custom tune and you could run 1.3 bar on pump... that will give you 600rwhp.. well thats what we do at least...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 5, 2010 | 05:06 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
markski
This is exactly what I did. I had K16s with a flash when I got my car. I got my K24/18gs ported, polished and ceramic coated, 1 bar wg, 5 bar, exhaust, clutch, a really good tune and a ebc. The car was a rocket compared to when I bought it. There was no comparison. I would only get the K24s if you're going to get the 18g upgrade.
Old Jul 5, 2010 | 05:52 PM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
I think being you have a TIP.. you need to speak with a tuner that knows the TIPS, I heard some packages that work well on the 6 speed cars dont work as well on our TIP cars
Old Jul 5, 2010 | 06:31 PM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Proto 18g's w/clip turbines + injectors would be way to go!!!
works awesome even on tip car
Old Jul 5, 2010 | 07:10 PM
boca996tt's Avatar
without sounding stupid here.. what is clipped turbines?
Old Jul 5, 2010 | 07:19 PM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
to answer the question, I went from 16's to 24's- the difference was little lag but much more power up top- very noticeable. Of course, what others have said regarding hybrid turbos makes sense if you are going to spend the money.
good luck!
Old Jul 5, 2010 | 08:40 PM
unvmy996's Avatar
clipping the turbo wheels
Old Jul 5, 2010 | 08:47 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
did the 18g with inj. + flash very noticeable top end, after 3rd.
Old Jul 6, 2010 | 12:21 AM
alex55's Avatar
guys don't forget that i have a tip and i don't want to spend 4000euro to upgrade it, too much money in these days, so the hp must be not so high.
so if I will do only k24 it will not be a very big difference, only more power at the top...
thanks guys!
Old Jul 6, 2010 | 01:30 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Alex, I don't think the tip will have problems holding 500-550 whp..
I'm in the exact same situation, and I trust what Mark says.
I know a few k24 TT's here, but noone of them is nearly as fast as the Punisher's 18g car....just look at his vids for example, he eats every car with ease, including chipped 7GT2's, LP560,GTR's...
I say stick to your k16 or do a proper job upgrading to 18g's or other hybrids (even a 16g is a bigger wheel than the straight k24 for example).
