TIP Transmission Removal
Old Jul 8, 2010 | 12:23 AM
Griffon345's Avatar
Griffon345 is infamous around these parts
Anyone removed their TIP transmission? I have a leak in the seal forward of the converter and need to get the trans off. The manual only speaks of removal of the entire engine. I wonder if the trans can be removed without taking the engine out? (I hope!!!)
Old Jul 8, 2010 | 01:11 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
where is you leak, at the TQ? if so you don't need to take down the gearbox.
Old Jul 8, 2010 | 02:50 AM
Griffon345's Avatar
Looks like the seal on the gearbox side of the TC. Inside the bell housing. The sump seal also leaks but that is the simple one.
Old Jul 8, 2010 | 05:36 AM
alex55's Avatar
I had a problem with a seal that porsche doesn't sell, they told me that i must buy the gearbox but it was an easy fix.
you must take down the drive shaft and the front part of the gearbox, not all the gearbox
Old Jul 8, 2010 | 10:24 AM
Griffon345's Avatar
alex what seal did you have to replace? Buy a gearbox to replace a seal!!??
Old Jul 8, 2010 | 10:31 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
I was speaking with 9ff yesterday on the same topic of Tip removal. He recons it can be done with the engine still in place. He says the engine requires propping up at the bell housing end but the box will come out along with the TC if you undo the TC bolts and it can be done on axle stands. Which is good news as I want to do a Tip upgrade before I start on more power and I dont have a ramp.
Frank
Old Jul 8, 2010 | 11:21 AM
alex55's Avatar
yes because of a seal
http://www.autoatlanta.com/porsche-p...-05/320-01.php
the big one w/o part number!
I put some pics with a gearbox maybe it helps you!
Old Jul 8, 2010 | 09:12 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Thanks Alex,
That's just the diagram I was looking for. I'm gonna be tearing into that part of the trans. If I take that cover apart is all the trans fluid gonna come out?
I have excessive play at that front output shaft and probably a bad bearing.
Did you make a new paper gasket or just used silicone?
Old Jul 9, 2010 | 12:13 AM
alex55's Avatar
I don't remember if anything (fluid) fold down, maybe a little bit. you can not find the gasket, I use the silicone from the fabricator of the gaskets, a special silicone that can stand at high temperature.
ps. the pics are not from my car
Old Jul 9, 2010 | 03:37 AM
adam699's Avatar
Well I figured I'll check.
Be ready with some buckets. I'd say about 3 quarts/3L came out.
Below is the thread I just made with pics. This is definitely not a beginner DIY so unless you got some thick wrenching under your belt, have a ton of tools and resources and a VIP membership card to Harbor Freight, attempt at your own risk...BTW I just love how logical and easy this car is to work on.
https://www.6speedonline.com/forums/...ml#post2902588
Old Jul 9, 2010 | 02:00 PM
Adam,
This post is an eye opener.
The Manual box does not have a transfer box, but it would seem that the Tip has got one looking at the pics you have posted.
Is that transfer box separate from the main auto box. Does it have its own oil. If not. how/what method did you use to refill the whole box again .
The w/s manual makes it sound a complicated and long winded affair!!
Thanks for any info,
Frank
Jul 29, 2019 11:13 AM
midwestamv8
Audi
Sep 9, 2015 11:53 AM
993 Guy
Sep 4, 2015 07:48 PM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
