997SSK Short Shifter advice?
Old Aug 5, 2010 | 06:59 AM
silverlight's Avatar
silverlight is infamous around these parts
Hi - I recently had an OEM 997SSK short shifter installed after reading all the views here on the forum that it was generally viewed as better than some of the alternatives. What I'm finding though is that between 1st and 2nd gear in particular it's notchy, can really get stuck between the gears - not the "butter smooth" that I've read about. I'm assuming this might be as a result of how it was installed/adjusted? Just feels "off" to me when switching between the lower gears. 3rd to 4th is better and 4th to 5th is relatively smoother, etc.
Any suggestions?
thanks!
Old Aug 5, 2010 | 07:48 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Old Aug 5, 2010 | 08:15 AM
Pull the center console off and readjust the shifter. If they did not mark the shifter cables when they pulled them out there is a chance that they were not set properly which can cause shift issue, as well as not being able to get into reverse.
#TeamAIM
Old Aug 5, 2010 | 08:30 AM
Thank you both. Sounds like an adjustment issue. Had a dealer install it, and my impression was this was the first time they had done a 997SSK in a 996.... to answer some of the above questions implied by the other link -- (1) getting into reverse is okay, but requires a little play with the shifter before it will take, (2) never pops out of 2nd gear, (3) just sticky getting into first, (4) moving from 1st to 2nd I feel like I'm doing 2 discrete shifts in a straight line - the initial move to neutral where I hit a block, and then a fairly smooth move to 2nd gear, and (5) a generally "thick" or "heavy" feeling moving around relative to the stock shifter. Overall, everything works, but all the benefits of short shifting more than lost/given up by the bump I hit while passing neutral and the thick feel (would prefer a looser feeling obviously for fast shifting)
I will try to go back to them and have them re-adjust this weekend.
Old Aug 5, 2010 | 08:40 AM
Things you are describing are definetly an adjustment issue. Tell them to take the center console off, adjust cables and make sure it shifts properly into every gear including reverse before reassembling.
#TeamAIM
Old Aug 5, 2010 | 11:56 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Old Aug 5, 2010 | 12:01 PM
996twin_turbo's Avatar
996twin_turbo is infamous around these parts
Out of curiosity, which SSK did you pick up? OEM?
Old Aug 5, 2010 | 12:09 PM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
Maybe you missed it in his post
"Hi - I recently had an OEM 997SSK"...
Old Aug 5, 2010 | 10:40 PM
Originally Posted by 2muchtime
Thx for the link. Since I paid the $$ to the dealer for the install will first try to get them to do the appropriate adjustments before taking on such a project (but may be a helpful tutorial for them -- have this feeling they didn't mark prior positions on the cables...)
Old Aug 5, 2010 | 10:56 PM
Turbo Fanatic's Avatar
I suggest doing the Gbox Detent while you're at it.
Old Aug 5, 2010 | 11:09 PM
Good suggestion. ordered the "upgraded" version for sale (aka $20 price increase)
Old Aug 6, 2010 | 12:09 AM
Info:
http://www.gboxweb.com/detent.html
getting mine installed next week
Old Aug 6, 2010 | 12:32 AM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
I have the detent and it makes shifting more notchy...but know it helps saves your tranny is great.
Old Aug 6, 2010 | 07:47 AM
lol. sorry about that
steve harris
Jun 10, 2017 12:17 AM
nal991
Sep 11, 2015 09:05 AM
997zen
Sep 7, 2015 07:13 AM
