electronic boost controller
Old Sep 5, 2010 | 12:54 PM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Hello,
after installing an EBC should i disconnect the factory solenoid boost(N75)?i only disconnected the hose going to the wastegates than connect it to the ebc.
Old Sep 5, 2010 | 03:29 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Eitheir is fine. I disconected hoses and drove for a while. Later I took solenoid out. No issue. Make my car 0.1 lb lighter.
Originally Posted by autodynamics
Hello,
Old Sep 5, 2010 | 03:36 PM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Old Sep 5, 2010 | 05:17 PM
Hello,
You should do what your tuner tells you... we take it out....
You should also wire the EBC the way they tell you... and this is crucial.. get this wrong and you may have some major issues...
this is how we do it on internal WG applications...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 5, 2010 | 10:19 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
listen to marek he knows his stuff
Old Sep 6, 2010 | 09:00 AM
When the max boost is set to 1.4bar(per example),should i see 1.4bar in all gears?
Old Sep 6, 2010 | 09:21 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
I want to know that too
Old Sep 6, 2010 | 09:37 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
this can depend on the turbos ability to actually create that much boost with current conditions.
for instance in cool/cold weather my car makes 1.2 bar in hot summer texas days usually only1.1 bar or 1.0 bar
heat intercoolers and humidity can make a difference now if your running big turbos they generally have less issues building low boost like this and they also dont create as much heat when doing so.
Old Sep 6, 2010 | 09:51 AM
what i want to know is :should i see 1.4bar in all gears or the boost has to be progressive,1.2bar in 2ndgear,1.3 in 3rd....etc......
Old Sep 6, 2010 | 09:53 AM
this is a question for your tuner the person who wrote the software for your car. But you may not have enough exhaust volume in 1-2nd gears to build 1.4 bar you might not see it until 3rd n 4th gear
Old Sep 6, 2010 | 10:06 AM
boost will increase as you go from 1st to 3rd... 3rd is the full boost gear...
9.66
click to view
Old Sep 8, 2010 | 10:15 AM
Thanks Mark
PV=nRT.
Sep 9, 2022 06:06 PM
Texas1
Sep 20, 2015 09:12 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
