K24 20G setup
Old Sep 20, 2010 | 09:17 PM
Y3LO 01's Avatar
Y3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud ofY3LO 01 has much to be proud of
K24 20G setup
I’m ready to upgrade the turbos on my 996. I’m leaning towards a K24 setup rather than an Alpha setup. I feel that 600whp is the limit on a tiptronic. True or false?
Are the 20G turbos significantly more efficient on 91 octane than the 18G? I would expect the lag difference to be minimal but the top end power on the 20G to be much better and much more efficient on 91 octane.
Any issues with boost creep with these turbos when running an internal wastegate?
Is it realistic to run 1.3-1.4 bar on 91 octane without methanol with this setup? I would upgrade my intercoolers to GT2 intercoolers (or equivalent upgrade), install injectors and reflash.
Thoughts?
Old Sep 20, 2010 | 09:19 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
subscribed for some info myself.
Old Sep 20, 2010 | 09:33 PM
unterbergamotte's Avatar
unterbergamotte has a spectacular aura aboutunterbergamotte has a spectacular aura about
The K24/20's are not for the faint of heart. One has to commit to serious horsepower mods. They require larger than GT2 IC's and larger piping throughout. Injectors, Fuel assistance, Clutch... YOU HAVE TO BE READY TO FLY.
I just got a pair of Protomotive K24/20s and contemplating..
Old Sep 20, 2010 | 09:42 PM
unvmy996's Avatar
Thoughts?
no on 91 oct you cant take advantage of the 20s , the 20s shine on high boost.
power on a tip im not sure but i think you can go abit higher i know a few people on here that run a bit more power with no issues .
proper calibrated waste gates you will be ok .
some tuners like to run higher boost on less timing and vice versa, so you would have to talk to your tuner about this but i wouldnt recomend it , i would run meth injection since you have 91 craptane.
gt2 intercoolers are a waste , dont waste your money , save it and get a nice set .
for 20s you need full supporting mods , intakes etc , prefferebaly a blow through set up , or they WILL choke up at high boost . i would suggest the proto style full intake setup . y pipe, ford maf blow through set up , proto style intakes relocated in the fender wells .and IC's .injectors and ofcourse a retune.
Old Sep 20, 2010 | 10:01 PM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Thoughts?
Here is tiptronic 996tt w/Protomotive 20G's full system on 1.25bar ( pumpgas )
http://www.youtube.com/watch?v=DT7U0_vnq_s&feature=player_embedded
Old Sep 20, 2010 | 10:03 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
I would not run 1.3-1.4 bar on 91 with 20gs unless you're intent on blowing up your engine. I only ran 1.1 bar on my 18gs on 91 octane. If you're serious about going with a 20g there are a lot more supporting mods that should be addressed. Also, I wouldn't consider going with the GT2 intercooler as an upgrade regardless of what turbo you decide on. I do not consider them to be an improvement over the stock ic on the 996tt. They're just not worth it. The 20g is a serious beast. There are a few on here that have the 20g. I would talk with them about it. Good luck!
Old Sep 20, 2010 | 10:04 PM
Shotcaller's Avatar
The same owner send his tranny to MKB then he went from 20G's full system to Protomotive alpha 3076...Here is the video...still on pumpgas
http://www.youtube.com/watch?v=DaJxy...layer_embedded
Old Sep 20, 2010 | 10:05 PM
20gs can easily put down 660rwhp at 1.4 bar with supporting mods.. ours did... but 91 octane really blows... thus you need ICs, intake , injectors, 2nd fuel pump kit( the rest is assumed you already have... otherwise the 20gs will be a disappointment... UNVMY996 had the 18gs, 20gs and now my bigger kit... he's a good reference point...
Boost creep? NO we run EBC and can control that via the set gain settings....
If dont plan on doing it right dont do it... you will be disappointed...
do this along with your20gs and you will fly: ask anyone that has the set up...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 20, 2010 | 10:22 PM
Y3LO 01's Avatar
Thanks for the insight.
As for the injectors, does everyone run 62lb injectors? If so, what is the limit of these injectors with a 20G turbo at 1.4 Bar? Are these injectors close to maxing out at this point or is there plenty of room?
Can you accomplish the fuel delivery requirements without resorting to additional or high pressure pumps? Can you just run larger injectors (80lbs) and lean it out to accomplish the same result?
Old Sep 20, 2010 | 10:30 PM
we run 630cc, 750cc, 850cc and 1000cc injectors.. all for different applications...
My car made 871rwhp with 630cc( 60 lbs) with 2 pumps parallel. However, in my pics thats the cheap cost conscious series set up.... and thats good for upper 700rwhp...
injectors are not the problem... the pump is... or you need to redo your fuel lines and and the fuel rail... so both approaches achieve the same result... one with 2 pumps the other with one...
BTW, its one additional fuel pump not two...
No 80 lbs is not the answer...
No one will sell you a set up with your own purpose in mind.. you are playing with fire so I suggest pic a tuner and go with what works... I have seen many guys ask question, do the research, then think that they can do it on their own... only to come back crying... so be smart.....
good luck
markski
9.66
click to view
Old Sep 20, 2010 | 11:06 PM
Y3LO 01's Avatar
good luck
markski
Makes sense. I assume there are no issues on a tiptronic and maintaining AWD.
Old Sep 21, 2010 | 12:26 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
You will need to reinforce your tip. Good luck!!
Old Sep 21, 2010 | 01:51 AM
depends .. but 600rwhp is about the max.. evoms offers a stall converter...
9.66
click to view
Old Sep 21, 2010 | 09:30 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Interesting thread
Old Sep 21, 2010 | 09:44 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
If you have a Tip, I wouldn't go with the 20g. The 18g would be at the boarderline on your tranny and 20g is wayyy over.
