Tuning... Dyno vs Datalogging
Old Oct 12, 2010 | 06:44 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
What are your feelings in terms of getting the most out of your car, do you think it can be done datalogging the car and sending files back and forth? Or do you think your cars that much better served tuning on a dyno?
Old Oct 12, 2010 | 07:09 PM
both options have their merits...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 12, 2010 | 08:25 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
i think basic turbo kits can get good results via datalogs, big builds custom, one off's need to have some dyno time to squeeze all the power out
Old Oct 12, 2010 | 10:59 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Dyno. With emulator you can tune live and change parameters on the spot. End result will be a smoother tune if done properly.
Old Oct 12, 2010 | 11:53 PM
Shiv's Avatar
Shiv has a spectacular aura aboutShiv has a spectacular aura about
Dyno is great for base calibration. Because you aren't going to be able to test individual rpm/load combinations on the street. And it's also good for "torture testing" because you can sustain high load/steady state conditions that you couldn't on the street unless you were towing a motor home.
But when it comes to acceleration performance (ie, rowing through the gears), it's hard to beat the real world. Shifting through gears with true non-contaminated air (which is usually the case with dyno shops) will present load swings that you will not likely see on the dyno. And being able to manage these load swings with seeing transient detonation/KR or rich bog is what separates a typical aftermarket tune from a good one.
So both types of tuning are necessary if you want the best possible tune
Shiv
Old Oct 13, 2010 | 01:33 AM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
Do dynos provide the same engine loads as doing real world street pulls?
Old Oct 13, 2010 | 07:21 AM
LiNks's Avatar
Ok that makes sense
Old Oct 13, 2010 | 08:34 AM
Robin@EPL's Avatar
Robin@EPL is infamous around these parts
A combination of both is the best way to achieve OEM-quality calibration. You can't simulate all conditions on a dyno, and you can't simulate all conditions on the street.
COBB Tuning
Nov 3, 2015 08:39 AM
Emre@Esmotor
Oct 19, 2015 12:06 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
