Question for all of you Cab owners. Do your top rattle or Squeak?
Old Jan 13, 2011 | 03:41 PM
ggarza007's Avatar
ggarza007 is infamous around these parts
Question for all of you Cab owners. Does your top rattle or Squeak?
I have a 2004 996 TT X50 Cab. I have a rattle or squeaking noise right above my head on the driver’s side, on the inside of the top. If I push or apply pressure on the top with my hand, the noise goes away. What do you guys think it is? Have any of you guys experienced this? Thanks
Old Jan 13, 2011 | 07:31 PM
X98boardwell's Avatar
X98boardwell is infamous around these parts
I little noise here on my 04. I have only 9,000 miles as well but it is extremely minimal... not like you are describing. My concensus is that there must be a little movement and that is what I think I have.
Typically while entering driveways or gas stations on an angle with the flex.
Old Jan 13, 2011 | 08:42 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
Just reaching, but have you fiddled with the sun visor at all?
Old Jan 13, 2011 | 10:33 PM
langer911's Avatar
langer911 is infamous around these parts
I have the same problem with my.
Old Jan 14, 2011 | 10:23 AM
bsprad's Avatar
bsprad is infamous around these parts
I have a similar issue with mine. Every now and then I think about looking into it, but it hasn't bothered me enough yet.
FYI, you can use the same temporary fix that I am using right now:
-Grasp volume **** on stereo
-Turn clockwise until squeaking is no longer heard
If you find a permanent fix I'd certainly be interested. Likewise, if I ever dive into it I'll post my results.
Old Jan 14, 2011 | 03:18 PM
ggarza007's Avatar
I am tired of the squeaking noise. This weekend I am going to open the top half way and try to remove the top head liner, to see what is causing this. I am thinking that their must be some plastic rods that may be rubbing together which is causing this noise.
Old Jan 14, 2011 | 03:40 PM
falcon7x7's Avatar
falcon7x7 is a splendid one to beholdfalcon7x7 is a splendid one to beholdfalcon7x7 is a splendid one to beholdfalcon7x7 is a splendid one to beholdfalcon7x7 is a splendid one to beholdfalcon7x7 is a splendid one to beholdfalcon7x7 is a splendid one to behold
There is a fix for this problem, I hate say it, but see your dealer. The kit is approx. $100 plus labor. My dealer put duct tape on the "prongs" that align the cab top to the windshield, and said to have the perm fix done at the next service. So far no squeak or rattle with the tape.
Old Jan 14, 2011 | 03:42 PM
falcon7x7's Avatar
NO NO, there is a simple fix.......see my other post.
Old Jan 15, 2011 | 09:42 AM
OCNYPORSCHE's Avatar
OCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura aboutOCNYPORSCHE has a spectacular aura about
There is a Porsche TSB available on renntech that explains all of the trouble points and how to fix. Really great info and it worked for my 04 TT Cab.
Old Jan 15, 2011 | 03:34 PM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
Interesting, as my top is quite quiet (try typing those two words fast).
04 X50 Cab.
Perhaps the TSB was applied before I bought it.
BTW, I have over 70K miles
Old Jan 18, 2011 | 01:20 PM
ggarza007's Avatar
Do you guys have the link for the TSB available on renntech. Thanks
Old Jan 18, 2011 | 01:47 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
My 2004 cab's top doesn't make noise, but the wind-delector does (very little).
Old Jan 18, 2011 | 05:06 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
its a soft top, its going to make some noise, happens to my 04 as well, not overbearing at all. Winter is always going to be worse as everything can be heard. Love the cold!
Old Feb 27, 2014 | 02:45 PM
sswalters's Avatar
sswalters is infamous around these parts
I hate to revive such an old thread, but I had the exact same symptoms as the OP. Your idea to put duct tape on the retaining hooks on the top worked perfect! No rattles!! Also, I applied several coats of Einsettz Gummu Pflege on the rubber. I don't know which solution was the one that worked, but I don't care.
I'll also ask about that permanent fix at the dealer you referenced. Thanks for a perfect solution.
su_maverick
Sep 15, 2015 02:57 AM
pshep138
Sep 1, 2015 09:45 AM
jmbmm
Aug 28, 2015 02:01 PM
rnl
Aug 26, 2015 02:36 PM
saline
Aug 19, 2015 12:25 PM
