Coolant Last Forever NFW
Old Mar 24, 2011 | 07:29 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The dealer has said the engine coolant last "forever". This is just not
plausible. Nothing mechanical last forever especially associated fluids. Maybe they just want to sell you water pumps and radiators when the coolant turns bad. Anyone have a real world idea of coolant change intervals on a 996TT. As an aside, BMW and MBZ also said their tranny fluid is good for 100K. Fat chance with all the wear parts inside an auto tranny. Why do they perpetuate these myths.
Old Mar 24, 2011 | 07:49 PM
landjet's Avatar
There was a recent tech question in Excellence where the answer was to change it every couple of years. Only trouble is the coolant is not cheap and the car holds a lot, 7.5 gallons.
Old Mar 24, 2011 | 08:39 PM
DTM-POW3R's Avatar
Awaiting Email Confirmation
DTM-POW3R is infamous around these parts
Coolant is dirt cheap no matter what you use, watter wetter, engine ice whatever. If you use it on track a lot i'd probally change once a season or every other. 7.5 gallons is a lot and im assuming its because extra heat being generated by the turbos even tho they are oil cooled.
Old Mar 24, 2011 | 11:16 PM
pwdrhound's Avatar
Is that correct?? The dealer told me I need 2 gallons of the pink stuff for a coolant change on a 996tt...
Old Mar 25, 2011 | 05:13 AM
landjet's Avatar
7.5 gallons according to the owner's manual.
Old Mar 25, 2011 | 08:58 AM
Aboy.GT2's Avatar
Aboy.GT2 is a jewel in the roughAboy.GT2 is a jewel in the roughAboy.GT2 is a jewel in the roughAboy.GT2 is a jewel in the rough
That is the total capacity of the system. However it is filled with a water and coolant mixture not just coolant.
Old Mar 25, 2011 | 06:59 PM
landjet's Avatar
Isn't it supposed to be a 50/50 or 60/40 mix?
Old Mar 25, 2011 | 07:25 PM
jpflip's Avatar
THe dealer was right! Look at this page from the repair manual. But, I guess, and this is a guess, the coolant loose his property with time like oil and grease etc....
Old Mar 25, 2011 | 07:59 PM
jpflip's Avatar
The mix depend of the temperature of your location (note, see the difference in boil over protection...)
60% antifreeze 40% water= -62F/52C boil over protection: 270F/132C
50% antifreeze 50% water = -34F/-37C boil over protection: 265F/129C
Old Mar 26, 2011 | 12:07 AM
djantlive's Avatar
i would change it every 5-6 yrs. typical coolant is 3 years so I figure double life.
those coolant are indeed expensive. it's like 12 a quart or something.
Old Mar 26, 2011 | 12:15 AM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
Most cars prior to the wonder fluids was ever 30,000 miles..
there is almost no way you could ever get out the 7 gallons. I have never done a coolant change on a 911. might want to read the book some cars will have a bleeder value, if you don't crack that when refilling you will never get it full..
I would not mix the coolant if you get out 2 gallons put in 2 gallons..
as for the tranny fluid if your car has a drain plug on the tranny (automatic)..every time you change the oil do the tranny as well you will only get a couple quarts out.even though it holds about 9..
dealer at 100k would love to sell you a tranny flush for about $300+..
but if you do your own oil changes then removing the drain plug will be
no problem for you.
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
