TT suspension "sag" in rear?
Old Mar 30, 2005 | 10:32 AM
GENERAL LEE's Avatar
Senior Member
GENERAL LEE is infamous around these parts
Question TT suspension "sag" in rear?
I've noticed that stock TT's look like they sag in the rear. Is this just from the weight of the engine, or something else? Is it normal?
Old Mar 30, 2005 | 10:43 AM
jwa's Avatar
jwa
jwa is infamous around these parts
The front end is really light (nothing there) and the back end is heavy (engine) this offset causes the shocks in the back to wear out faster causing the "sag" look
Old Mar 30, 2005 | 11:19 AM
sharkster's Avatar
Yeps you are right... Just so you know the stock US suspension is pretty weak. My shocks were shot after 11K miles....
Old Mar 30, 2005 | 11:36 AM
Senior Member
Would the shocks be covered under factory warranty, or do they consider them a wear item. Thanks.
Old Mar 30, 2005 | 07:07 PM
jwa's Avatar
jwa
I believe that they aren't covered by the warrenty, but I could be wrong
Old Mar 30, 2005 | 10:10 PM
TCM's Avatar
TCM
TCM is infamous around these parts
Just another reason to switch to an aftermarket suspension!! After all, you always have to look at the bright side of things.
Old Mar 30, 2005 | 10:16 PM
ttgangsta's Avatar
ttgangsta has a spectacular aura aboutttgangsta has a spectacular aura aboutttgangsta has a spectacular aura about
Yes the Turbo has a tendency to sag in the back. When I had the PSS9s installed the tech kept about 10-20mm in the back to offset this sag as the springs set and wore down.
Old Mar 30, 2005 | 11:01 PM
jwa's Avatar
jwa
I don't think that just the TT's have them... I have seen a couple C4S's with that problem also
Old Mar 31, 2005 | 08:58 AM
Senior Member
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
