PSM/ ABS warning
Old Jun 24, 2011 | 07:33 AM
JFC's Avatar
JFC
JFC is infamous around these parts
PSM/ ABS warning
Please help ? i ve read so much previous posts but seems MAF is the main issue? i havent chk my brake lights yet, but does the cleaning MAF work?
anyone? thks!
Old Jun 24, 2011 | 07:51 AM
run the car at idle.... disconnect the harness at the MAf.. if the car changes a slight tone and or rpms change then the maf is working... you might get a CEL.. if not then your maf is done... disconnect the battery for a while to get rid of the CELs...
thats the fastest way to see if its busted or not...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 24, 2011 | 01:21 PM
nstea's Avatar
nstea is infamous around these parts
I got these warning lights recently and it was not the MAF. I took the car to the dealer and it was just a fuse. The part was $16 dollars and it solved the problem. It's been 4 months now and everything is working fine.
Old Jun 24, 2011 | 01:34 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Could be the most awesome warning lights ever. I was getting these warnings frequently, along with an occasional code for my break light switch. Replaced the switch, the ABS/PSM warnings stopped.
Old Jun 24, 2011 | 03:31 PM
SamboTT@ByDesign's Avatar
Old Jun 24, 2011 | 07:11 PM
JFC's Avatar
JFC
THks guys, gonna go chk the brake light and hopefully the" brake light switch" can solve my issue.
Old Jun 24, 2011 | 08:59 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
You should go get the codes read before you start throwing money at replacement parts. Here is a partial list of faults that will trigger that pair of lights: MAF, brake light switch, steering angle sensor, height sensor (on control arm), ABS sensors or control module problems... There are a lot more.
Old Jun 25, 2011 | 08:43 AM
JFC's Avatar
JFC
replaced the light switch and all the brake lights appear normal now + PSM /ABS warning light gone!
thks so much guys~~~~
Old Jul 20, 2012 | 06:22 PM
XLR82XS's Avatar
I get PSM/ABS lights ONLY when I turn the lights on (parking or headlamps). Scanned for codes, replaced faulty brake switch per code, problem still there. Everything fine until lights go on. Brake lights and all other lights working. Help!
airbusdrvr
Dec 27, 2015 07:43 PM
vkvmd
Oct 5, 2015 02:04 PM
DYL 911
Oct 1, 2015 02:47 PM
Batman-76
Sep 22, 2015 09:08 AM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
