Disconnected battery & shut the bonnet
Old Jul 30, 2011 | 10:59 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Classic problem but what do I do???????
JE
Old Jul 30, 2011 | 11:16 AM
statepkt's Avatar
statepkt is infamous around these parts
Open your driver door and the electrical fuse panel there.
There is a little jumper spot (red stickish thing that comes out) where you can connect a battery backup device. This will provide power to open the hood so you can re-connect the battery
Old Jul 30, 2011 | 11:34 AM
jpflip's Avatar
Or found the hidden unlatch cable....Right wheel well under the plastic liner....On the picture a view of what the cable looks like...
Mr. C4's Avatar
Even if the battery is disconnected?
Old Jul 30, 2011 | 11:37 AM
jpflip's Avatar
It should work because that's the way we open the forward trunk when the battery is completely dead....
Old Jul 30, 2011 | 11:47 AM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
The wire is a pain to find. Use the trick in the user manual, connect battery charger to the + in the fuse box, - to the door latch thing on the body/chassis. Then pop the trunk the normal way.
Old Jul 30, 2011 | 12:35 PM
Mr. C4's Avatar
Tried the wire which was a pain to find and still couldn't yank it to pop the hood so ended up trying the fusebox trick wich worked like a charm. Wish I had tried that option first!
Thanks guys for your help!
Old Jul 30, 2011 | 02:07 PM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
Fuse box trick does work pretty well. A little annoying, but works
Old Jul 30, 2011 | 03:44 PM
statepkt's Avatar
No problem.
That was the first thing I learned how to do on my TT because I had a dead battery. Certainly easier than fishing for wires :P
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
pwdrhound
11
Nov 25, 2015 01:18 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
