ksport coilovers
Old Sep 11, 2011 | 08:23 PM
  #46
VAGscum's Avatar
Originally Posted by acuteperformance
Did you swap to the rubber bushings?
Michael
Owner
Acute Performance
Mike,
I noticed you no longer have any Ksport products available on your site? Are you still a dealer? Why are they not listed?
Old Sep 11, 2011 | 09:35 PM
  #47
qfix's Avatar
qfix is infamous around these parts
Yes it can. The installer took the dampening ****, determined the range ( # of half-turns) and set it at the half-way point. This yielded a slightly softer, but not bouncey, ride than the OEM touring suspension (granted it was seven years old so I'm not sure if much can be drawn from that comparison). Hope this helps.
Edit: A before and after. Not the best photos.
2nd Edit: So far so good. I'm going to have the front raised slightly this weekend. No ride issues other than it scrapes when I pull out onto the street from the house.
Old Oct 4, 2011 | 08:56 PM
  #48
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Qfix how is it going.
Old Oct 5, 2011 | 08:52 AM
  #49
qfix's Avatar
So far no complaints. I had the coilovers set for a softer street ride and it's worked well. I was able to achieve stock alignment in the rear and just slightly more camber than stock in the front. The camber is just slightly out of range so there was not a concern about excessive tire wear. It definitely meets my needs for street use.
Old Oct 5, 2011 | 05:30 PM
  #50
pat's Avatar
pat
I would be using for street only also. Sounds good. Thanks for the update. I will have to get a set.
Old Oct 22, 2011 | 05:57 AM
  #51
pat's Avatar
pat
Update.. I ran into a used set of gt3 coil overs for 300.00 dollars so am putting them on now. I can't find the info for the bolt on the bottom of the damper for the front unit. Is the bolt and lock nut combination a dampening adjustment.
Old Oct 22, 2011 | 07:52 AM
  #52
pat's Avatar
pat
picture of coilovers
Old Oct 22, 2011 | 09:48 AM
  #53
VAGscum's Avatar
You may want to look into whether or not you can use those on the 996TT if you haven't already. You will need a shim adapter for the steering knuckle due to the smaller shock body used on the rwd cars. Also those upper shock mounts are most likely not going to fit because the 4wd cars have different strut mounts than the RWD cars. the angles are different. Not sure on the bolt pattern for the strut mounts. You may be able to use the stock 996TT one, but not sure if the shock shaft diameter is the same. The other concern I would have would be the swaybar link attachment points on the front shocks.
Old Oct 22, 2011 | 10:42 AM
  #54
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Those look like ones on ebay that needed revalving...
Old Oct 22, 2011 | 12:55 PM
  #55
acuteperformance's Avatar
acuteperformance is infamous around these parts
If anyone is interested in a set let me know.
Michael
Owner
Acute Performance
Old Oct 22, 2011 | 03:15 PM
  #56
k-ore's Avatar
Michael
Owner
Acute Performance
Can you pm me a price for a 996tt?
Old Oct 22, 2011 | 04:20 PM
  #57
jdholder's Avatar
jdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond reputejdholder has a reputation beyond repute
Michael
Owner
Acute Performance
I'd like a pm with price also! Do you still have the used set?
Jon
Old Oct 22, 2011 | 06:51 PM
  #58
DHealy's Avatar
DHealy is infamous around these parts
PM for 2001 996TT. Also interested in the used ones.
Old Oct 22, 2011 | 07:01 PM
  #59
pat's Avatar
pat
Vntpreformance... Yes those are the ones. They seem ok. I am in the middle of putting the fronts on. They are missing the sway bar links for the rear and I need to ge a pair of those. For 300 bucks these will give me something to play with. I may still get a set of the ksports. In another thread there was info that these could be revalved for very reasonable at bilstine.
Old Oct 22, 2011 | 08:17 PM
  #60
pat's Avatar
pat
The part numbers are 99633305191BJ0. Rear and
2399VE360706T0 front
