picking up
Old Sep 22, 2011 | 10:50 AM
18902man's Avatar
18902man is infamous around these parts
picking up
a 2002 tt. PPI is being done tomorrow and picking it up hoepfully Saturday.
Hopefully I know everything about the car after the PPI but will be my first time seeing the car in person.
Is there anything I should look for myself? I plan to look for
-manuals
-keys 2
-body and paint
-leaks but should be seen during PPI
-test drive
- anything else?
Old Sep 22, 2011 | 11:38 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
2ND GEAR POPOUT.
Cost me ~$6k to repair it.
There are a few threads on how to find it, I didn't do it thoroghly enough and it started about 30 mins after I drove away with the car. (And had 2 PPIs done)
Old Sep 22, 2011 | 11:52 AM
18902man's Avatar
how do you get it to happen? if it will happen?
Old Sep 22, 2011 | 12:29 PM
18902man's Avatar
ok seems to test on downhill or flat and hit gas and just quickly release throttle.
Any fixes or way to make sure it will not happen?
Old Sep 22, 2011 | 12:39 PM
Florida_996's Avatar
Florida_996 is infamous around these partsFlorida_996 is infamous around these parts
There is a vendor on this site, I believe G-box or similar that sells a kit to help prevent the issue. Though I don't think it will resolve if it's already happening.
Old Sep 22, 2011 | 05:18 PM
ard's Avatar
ard
Good luck on the new purchase... As you may know there is no 'common definition' on what goes into a PPI. Have you carefully researched that and told the shop your expectations??? Many PPIs don't pull codes nor over-revs for example. Something like a 'leak' could be called a 'weep' or 'seepage'...
Try and get a detailed maintenance history.
Florida- welcome to the site, impressive response with 4 posts on the G-box 'detent upgrade'. It will not 'fix' the problem if it exists. Someone is reading first, posting second!
A
Old Sep 22, 2011 | 05:33 PM
Good luck as others have mentioned. Ard, I think I read every diy and tech article on this site before I actually signed up. I was amazed at how many common issues have simple fixes
18902man's Avatar
yes getting from precision Imports in manchester, NH.
they do codes and i told them i want an over rev count etc. he said he would do the basics first drive etc body leaks and then discuss how to proceed on the PPI.
i would expect no leaking at all in this car. will call them tomorrow to discuss more as the PPI is getting done
Old Sep 22, 2011 | 06:24 PM
bng4god's Avatar
bng4god has a spectacular aura aboutbng4god has a spectacular aura about
couple of other knick knack things you can use to drive down the price.
1) Leaking rams for the hydraulic spoiler. You can see it if you pop the rear hood and look at the top part of the hood. The rams are the two black columns protruding on either end of the hood. The cost to replace ram parts alone are around $900 total for both. Oh, and if you do this, it will fail again.
2) Failing clutch accumulator. You can tell before you start the engine, press the clutch down if it's REALLY hard and then you start the engine and the difference is huge like now it feels feathery, then you have a failing clutch accumulator. Replacing the accumulator is not so bad but you might as well replace the slave cylinder which is likely to go soon as well. Oh, and if you do this, it will fail again... So if you do a search, the GT2 slave upgrade is another thing you might want to consider instead.
If both are present, you might use that to your advantage in the negotiation of price.
Old Sep 22, 2011 | 08:18 PM
vr4henry's Avatar
Not quite, in my experience.
Get it in 2nd gear, take it up to redline (not necessarily full throttle) then leave it in gear and coast (slowly) down to a stop. Coasting downhill will make it more likely to jump also from what I experienced.
Old Sep 23, 2011 | 05:54 AM
18902man's Avatar
Ok will do and will call ppi place to go over and make sure they do what I want.
Old Sep 23, 2011 | 07:05 AM
Ray C.'s Avatar
Ray C. is infamous around these parts
I just had the coolant expansion tank replaced for it's 10th birthday with 44k miles. The plastic material becomes dry and brittle over time and will develop a leak. The system can be preasure tested / check the ground at driver side rear after driving for coolant.
Old Sep 23, 2011 | 08:59 AM
18902man's Avatar
ok well talked to th shop and some concerns.
-tranny getting into third gear was difficult took a bit of force.
owner just said yeah he told dealer that under CPO and they said there was nothing they would do to the car
-alt bearing shot needs to be replaced
-pulsation in front brakes, but car hasn't been driven in 4 months so probably will go away lots of pads left
-clutch is grabbing pretty high has 42k miles on teh clutch so probably will need to be replaced down the line
-headlight plastic fading slightly just needs to be polished out.
everything else seems good no codes etc. thoughts?
anyone else have this thrid gear issue?
Old Sep 23, 2011 | 10:05 AM
18902man's Avatar
just spoke to Stan at gbox what a great guy. he said this was a pretty common issue if teh car was driven hard. oh well onto the next one
NRoy7
Jul 4, 2022 04:03 AM
ECS Tuning - BMW
Sep 14, 2015 12:36 PM
ECS Tuning - BMW
Sep 10, 2015 02:20 PM
ECS Tuning - BMW
Sep 4, 2015 02:35 PM
ECS Tuning - BMW
Sep 4, 2015 01:57 PM
