Power Steering Reservoir/Hoses HELP ASAP :(
Old Mar 12, 2012 | 01:53 PM
SaikoE36's Avatar
SaikoE36 is infamous around these parts
Hey guys So i did the gt2 conversion and everything but i did mess up the RED Connection of the power steering reservoir hoses Anyone know where i can just get those connections? Ive tried pelican parts. anther Porsche parts department and they said id have to buy the hose? Please tell me someone knows where to buy the connector? The Petosin is leaking from that area
Anybody?
Old Mar 12, 2012 | 02:01 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
From what I can see from the pix you are going to need hoses. Alls you have to do is have one little scratch and they will leak. I think you are going to need a new tank as well. I don't think you can just get the connectors. If you do find a source for the plastic connectors please share.
Old Mar 12, 2012 | 02:38 PM
SaikoE36's Avatar
Im sure its just the connector cause thats where the leak was coming from... the hoses werent leaking when i had the car on .... at least i didnt notice any
Old Mar 12, 2012 | 04:11 PM
pwdrhound's Avatar
I'm 100% sure it's NOT the red connector causing your leak as the red connectors on the reservoir tank DO NOT have any sealing function. They just keep the hose from popping out. An O-ring within the reservoir forms the seal. If you don't remove the hoses properly (a special fork type tool is needed to press in the collar evenly so you can pull the hose out) you will very easily put a tiny scratch in the smooth hose end nipple and that will result in a leak. If you don't correct it then the pentosin will flow down over the back of the engine and destroy the passenger side coolant pipe rubber seal. Ask me how I know. The red connectors (collars) are not sold separately and can only be acquired with the purchase of a new reservoir tank. Been there, done that.... In my case, I was able to get a faulty used reservoir tank from a member here for $50 just so I could get the red collars. There may be some used tanks laying around in people's garages.
Old Mar 13, 2012 | 12:15 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
New tank serious $
Old Mar 13, 2012 | 12:33 AM
pwdrhound's Avatar
Originally Posted by Blockhed
New tank serious $
About $550 or so....
Old Mar 13, 2012 | 02:14 AM
SaikoE36's Avatar
i know
Old Mar 13, 2012 | 02:17 AM
SaikoE36's Avatar
But i swear i saw the pentosin leaking from that connector where its broken.. not from the hoses
Old Mar 13, 2012 | 03:47 AM
pwdrhound's Avatar
It leaks from the junction where the hose nipple plugs in to the reservoir through the red collar. Again, the red collar has no sealing function. It is simply a retainer but the leak will come from the same area.
Old Mar 13, 2012 | 06:45 AM
sweeney186's Avatar
sweeney186 is infamous around these parts
The red collars only purpose is to release the finger retainers that hold the hose in when pushed toward the tank,no sealing properties.
Old Mar 13, 2012 | 11:51 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
IIRC there's a thread over here about how to modify the reservoir's connections to foolproof ones. I strongly recommend to search, read and do!
Pentosin, in addition to being harmful to rubber, is highly flammable! Don't ask how I know...
Basically it's done like this: Remove the reservoir and the pump. DIY if you have WSM or good instructions available. Disconnect pump's connection to clutch pressure drive. (Find the thread, it's all in there...) Weld shut all extra fittings and weld a AN male fitting for PS return line. PS feed line is already threaded, so no need there. Get new PS lines, custom ones... The fittings on the other end (towards the steering rack) can be reused for these custom lines if removed carefully.
EDIT: https://www.6speedonline.com/forums/...ir-change.html
Old Mar 13, 2012 | 10:34 PM
SaikoE36's Avatar
I couldnt find the DIY
Old Oct 25, 2024 | 01:04 PM
Maastricht's Avatar
5 Year Member
Maastricht is infamous around these parts
Adding this also in here.... I managed to get my hands on some of the (larger version) new red clips/grommets.
Unfortunatly only the larger version , and I'm actually still in need for the smaller version
I have a some spare ones. If anyone is interested let me know
Old Nov 3, 2024 | 07:53 AM
Maastricht's Avatar
5 Year Member
I now have both small & large plastic clips.
I have a few spare ones. If anyone is interested let me know.
Old Nov 3, 2024 | 01:11 PM
docwyte's Avatar
docwyte is a name known to alldocwyte is a name known to alldocwyte is a name known to alldocwyte is a name known to alldocwyte is a name known to alldocwyte is a name known to all
I don't need any now but probably a good thing to have as spares. I'll pm you
