Need help with oil change
Old Jul 12, 2012 | 08:20 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Originally Posted by rangerdick
Be sure to use a second wrench (I think 27 mm) on the tank itself to offset the torque of undoing the tank plug. Hope this helps. I PM'd you if you need local help. Good luck.
27mm is the correct size. If you don't have one (just as an FYI), it is not a very common size. I went to a few auto stores and the largest size they had was 24mm or 25mm. I ended up going to Lowes and they had 3 of them.
Old Jul 12, 2012 | 08:23 PM
FI_FTW's Avatar
Originally Posted by '02996ttx50
and to further veer OT, with apologies to the OP.. man, does 0-40 get thin in this heat!? or what! man.. time to 5-40 i think...
Yeah, I'm going with 5w40 next time. That will probably be a year from now though . I'll use the Shell stuff my neighbor (Ferrari mechanic) uses. Seems like good oil. That is also the weight my GTI uses, so that comes in handy.
Old Jul 12, 2012 | 08:24 PM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
I have owned my GT2 for almost 2 months now. I have since changed the transaxle fluid and the oil. Before attempting either fluid exchange I read every single DIY I could find on both procedures.
I may have gone a bit overboard w my process...on the other hand both the transaxle and oil change went smooth...so maybe my I was right to have all the info I could under my belt before starting.
My suggestion to you, and anyone else reading this thread is to not just go at these cars ***** nilly like you would your minivan. The dry sump system itsself adds a few extra steps as well as the turbos and the handful of sealing washers are...for starters..enoughg to get you scratching your head.
Soooo my suggesgion is to read the multiple DIY's on oil changes. Get the proper fluids, filter, and sealing washers and start again. This will most certainly up your odds of a successful DIY 996 oil change.
Old Jul 12, 2012 | 08:26 PM
'02996ttx50's Avatar
funny.. i'm looking for an old gti to beat up! so MY tt's oil will last longer btw changes.. right now, she's gettin a real daily workout, esp in this heat!
Old Jul 12, 2012 | 08:28 PM
FI_FTW's Avatar
I have a 2007 GTI with APR stage 1 software on it. It's also lowered on Bilstein sport shocks+Eibach lowering springs. That car is a LOT of fun to drive!! Fantastic value!
Old Jul 12, 2012 | 08:30 PM
7500.00 cash. tomorrow. we are local and fu*k the ppi. lol
Old Jul 12, 2012 | 11:31 PM
FI_FTW's Avatar
LOL!! I said 2007, not 1997
Anyway, sorry for the OT.
Old Jul 13, 2012 | 12:19 AM
contsaga's Avatar
contsaga has a spectacular aura aboutcontsaga has a spectacular aura aboutcontsaga has a spectacular aura about
I just changed the oil last week. Don't bother draining the turbos. The total amount of oil from both turbos filled about half of a Jello Pudding cup. You know the ones you buy already made for you in the super market.
Also, the oil filter canister is on very tight. The Autozone wrenches do not work. I've tried every one of them. The only ones that work is the official Porsche one and the Lisles #53700 wrench with a swivel handle. My mechanic friend used the Lisles one and loosen the filter canister in less than 10 seconds. It's on very tight. Also, the swivel handle gives you enough room to get additional swing room and get beyond the obstructions. See pix attached. 3rd pix show how a non swivel wrench hits the engine compartment lip. Also, the first one shows the swivel wrench swinging beyond the 'Y' pipe.
Use a rag around the filter canister, so you don't scratch it. Also, there is very little oil in the filter assembly. Use a rag or a syringe to get the little bit out. Probably about same amount as in the two turbos. Not much compare to the 8 quarts you've already drained. So, I don't think it's a big deal if you've left that amount in the turbos and the filter housing.
Old Jul 13, 2012 | 07:08 AM
can't blame a guy for tryin". ha.
Old Jul 13, 2012 | 07:25 AM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
Preparation breeds success.
Inspect your oil filter as well. Cut it open and look closely at it, will give a good indication of potential future issues. And/or oil analysis every once in awhile to start a baseline.
Old Jul 13, 2012 | 12:54 PM
FI_FTW's Avatar
I paid the $35 (or whatever it was) for the Porsche oil filter wrench and it's a breeze. The oil filter really shouldn't be on there that tight but I typically use a long breaker bar to loosen nuts and bolts; it makes it really easy and you don't hurt your hands by hitting anything when it finally breaks loose.
Torque wrench only to tighten though
alwaysbored786
Apr 19, 2016 05:51 AM
4ocious
Sep 1, 2015 06:44 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
