airbag control module
Old 08-11-2012, 02:32 PM
DeboTT's Avatar
DeboTT is on a distinguished road
Hello,
First let me introduce myself, my name is Tom and my car is a 2001 porsche 911 turbo. Anyway the other day I had to jump start my car and now the airbag light is on. Took it to the mechanic and code can't be reset, it looks like the module went bad. So I am in the process of figuring out what to do. Do i go and by a used unit and reprogram it or do I remove my exisiting unit and have it fixed? Thanks for your help
Old 08-11-2012, 05:19 PM
raineycd's Avatar
Been there...
https://www.6speedonline.com/forums/...ar-faults.html
Get the codes read. Start from there. If 195, I have an old module I got from another 6speeder. I'd be happy to give it to you to try! My main module died, I put this one in and it had more codes. Bought new main module, same codes - had to put both front seat belts pre-tensioners in...
That's my store in a nutshell!
Old 08-11-2012, 05:29 PM
Prche951's Avatar
Duct tape is the only airbag control module I know:
Old 08-11-2012, 06:11 PM
DeboTT's Avatar
Hi,
Thanks for writing back. I did read your thread, and I believe my codes were the same. I would try a new module but I have read that they need to be coded to the vehicle so you would have to take it to the dealer and im trying to avoid that. I did see that there are a few services that will fix your existing module for 50 bucks, I am thinking this might be the way to go. The only problem is I can't get the module out. Those gold tamper proof bolts won't break loose. The only tool I can think to use is needle nose vice grips but I can't get a good bight on the bolt. I was wondering how you got your old module out? I was thinking that if I have my old module fixed and then reset that may fix the problem. I know that when I jumpstarted the car that is what caused the problem so I am hoping that it is the control unit.
Old 08-11-2012, 07:58 PM
raineycd's Avatar
Originally Posted by DeboTT
Hi,
I read about those fix it guys to! Worth a shot I guess. After spending too much time and $ trying to avoid the dealer, I bit the bullet and went and got it fixed. $1800 later, it still is good! I wasn't comfortable knowing my airbags may not work...
I used pliers or vice grips. Mine came out pretty easily...
Old 08-13-2012, 03:48 AM
landjet's Avatar
Could one of you provide a link to the fix it guys please?
Old 08-18-2012, 05:20 PM
DeboTT's Avatar
http://www.airbagsystems.com/ This is the company that I sent mine to a few days ago. I have not heard anything yet, I will most likely hear on monday. I will let you know if they are able to fix my module.
Old 08-19-2012, 06:12 AM
landjet's Avatar
Thanks for the reply. I'd really like your feedback on this as my module is bad and I would love a cheap fix.
Old 03-29-2015, 05:48 PM
mrrrkva's Avatar
mrrrkva is on a distinguished road
How did it work out for you? Did they rebuild you module and where you able to rebuild your tensioner?
Old 04-07-2015, 08:32 AM
DeboTT's Avatar
Airbag Module
Hi sorry it took so long to get back to you. The airbag reprogram did not work and it was a waste of money. I ended up buying a new airbag module from suncoast porsche and had my independent shop program it into the car. The problem was the control module and not the seat belt tensioner. I forget the price but all in I think it was about $600. That was a very costly jumpstart. I keep the car on a battery tender now. I hope this helps
Tom D
01 turbo
Old 04-07-2015, 08:37 AM
DeboTT's Avatar
Yes it has to be coded. I took mine to an Indy which was cheaper. They need the correct computer which is expensive so you will need to find and Indy that has it. Where r u located?
Old 04-07-2015, 08:40 AM
DeboTT's Avatar
Airbag module
I had mine fixed by an Indy which was cheaper. They do need to be coded so you need to find a shop that has the computer. Where r u located?
adnanm3
11-22-2023 02:43 AM
Bodessem
09-10-2015 02:50 PM
albert@velosdesignwerks
Audi Vendor Classifieds
09-09-2015 10:28 AM
BMW Vendor Classifieds
09-09-2015 10:27 AM
Audi
09-09-2015 10:13 AM
Quick Reply: airbag control module
