Updated Headlights
Old Aug 2, 2013 | 04:17 AM
  #181
TheInfamousDrew's Avatar
TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !
Originally Posted by nick49
This whole thing is crazy!
I just now checked and the litronic headlights lights for the Turbo are $6250 a pair. I knew they were a lot but forgot just how much.
Yikes!!
I thought about doing this my self, but after seeing what it would cost if I screwed things up.....probably not...lol
Ive owned several BMW E46's and those headlights are serviceable, you can unclip the lens from the housing and paint anything. Ive done this on all the ones I owned so I have a bit of experience painting headlight parts.
One thing I can say about the out-gassing, it is most likely the type of paint they used or it could also be the silicon sealant.
Old Aug 2, 2013 | 05:59 AM
  #182
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
In that case... As I am contemplating putting mine together.
Any recommendations infamous dew ?
As far as silicone or sealing?
Old Aug 2, 2013 | 06:15 AM
  #183
If my memory servers me correctly, it was a small diameter butyl tape.
This is what a lot of OEM manufactures use.
Old Aug 2, 2013 | 07:58 AM
  #184
jonty's Avatar
jonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to all
How was the separation of the lens from the housing with the factory sealant? was it just Like Steve's video or do you have any additional comments or tips?
Old Aug 2, 2013 | 08:11 AM
  #185
stilov's Avatar
I didn't watch the video. I did one at a time. oven at 215 for 20 minutes. I use a small prybar, an exacto type flip open pocket knife and then I have one of those plexiglass cutters...used that too.
It took a couple times baking each one to get all the way around.
I was able to cut out a lot of epoxy too, so thats good.
I saw one thread where someone used window weld to glue them back. I like the idea of silicone bc if I don't get a great seal, I can redo it.
Im not sure about the tape idea, because there is still some remanent of the epoxy and I don't see it flowing well around to seal it.
Old Aug 2, 2013 | 08:30 AM
  #186
jonty's Avatar
Thanks for the feedback might try this this weekend.
Old Aug 2, 2013 | 08:54 AM
  #187
Steve B.'s Avatar
Steve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to beholdSteve B. is a splendid one to behold
Steve B, yes your lights look ruined. I don't need to be more descriptive, you can hide a lot of the imperfections by taking a pic. Any updates on this? Did you get them looking perfect yet?
I have a body shop putting 4+ hours into each headlight to try and make them right. He is telling me they will eventually come out great, but he had to strip all the paint and do a ton of work. Still havent seen them yet. In the meantime, I got a set of used lights that are in...
After all this, honestly, I may not even end up using the painted lights. Stockers look great!
Old Aug 2, 2013 | 01:43 PM
  #188
stilov's Avatar
After more research...maybe I will try the tape. Apparently it flows a bit when heated up and does not put off the vinegar type gas that some silicone sealants do.
Old Aug 2, 2013 | 02:24 PM
  #189
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
I used simple black silicone and have had no issue with the lenses fogging. This is after being installed on my car for four months.
The channel that the lens sits in is pretty large and takes a lot of silicone to fill the channel before assembly.
For reference, one tube of silicone was not enough.
Later, Steve
Old Aug 2, 2013 | 02:34 PM
  #190
That is an accurate statement.
This is why people use it instead of silicone.
Old Aug 3, 2013 | 02:59 PM
  #191
stilov's Avatar
Is it better if I put the tape on the edge of the housing that goes into the slot, or the slot itself?
Then what? push it in and then heat it up in the oven for a bit to get it squishy?
Any tips?
Old Aug 3, 2013 | 10:48 PM
  #192
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I haven't commented in awhile ....
I do NOT recommend using black silicone, I unfortunately will have to take mine apart AGAIN. I subsequently did a alot of research, you want to use the Butyl sealant tape to reseal the headlights. The haze on the inside of the lens can be caused by not only paint gassing but the silicone. I waited about a MONTH before resealing, and I still developed a light haze which was caused by the silicone sealant. If you are picky, you will NOT be happy. Use Butyl tape, my research showed that others had issues with silicone as well.
This has ended up being a complete pain in the *** for me, still hoping to salvage the lights, but I'm not so sure. Hopefully I don't have to repaint again.
Originally Posted by TheInfamousDrew
Yikes!!
Old Aug 4, 2013 | 05:49 PM
  #193
stilov's Avatar
Done. I'm about 85% happy. I think the turn signal tint is too dark. It shines orange through but not much.
Old Aug 4, 2013 | 08:32 PM
  #194
Th_Dude's Avatar
Th_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond reputeTh_Dude has a reputation beyond repute
If you're looking to eliminate the orange from peeking through, try these...
Philips - Silver Vision PY21W (Pair) : Amazon.com : Automotive Philips - Silver Vision PY21W (Pair) : Amazon.com : Automotive
Old Aug 4, 2013 | 09:09 PM
  #195
stilov's Avatar
Not at all. The lenses are tinted. I need a bright bulb to shine through the tint.
