Help Please!! My 2001 996TT refuse to take fuel!!
Old Oct 16, 2012 | 08:35 PM
  #31
BV996turbo01's Avatar
BV996turbo01 is infamous around these parts
Yes,
Warranty coverage in California on emission control is 7 years 70,000 miles which ever come first. What I don't like about dealer services is that they just go by the book and start replacing what ever they think it has to do or related to the problem. Case and point, a few year back, I had the key ignition malfunction (when you turn the key you have to manually turn it back after the car started). I brought it in to the Auth. Dealer and they wanted to replace the entire steering control arm estimated at $1600. I did my search and ended up replacing the cartridge behind the key socket and solved my problem. Total cost $28 and 10 minutes labor......I hope that someone can point me in the right direction with this new fuel' s problem. BV
Old Oct 16, 2012 | 08:43 PM
  #32
rmc1148's Avatar
I would disconnect hose off valve and make sure its clear,Im guessing as to how this is configured as I have not looked into it online etc or looked at my car.It may pay you to research a good indy shop in your area. Im going to try and find a diagram to check it out further.
Old Oct 16, 2012 | 08:55 PM
  #33
rmc1148's Avatar
autoatlanta has the layout in their auto parts look up= its looks complicated I would find it easier to understand looking at it in person,you will have to dig in and do some hands on checking .
Old Oct 17, 2012 | 01:49 PM
  #34
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
There is a valve that connects to the fuel neck it's faulty. I will grab the part number for you.
Old Oct 17, 2012 | 02:26 PM
  #35
WOODTSTER's Avatar
In the interum you need a long narrow screwdriver or a coat hanger to hold that flap open manually to get fuel it. This is a real PIA and had happened to many of us.
MK
Old Oct 17, 2012 | 04:11 PM
  #36
Hi Chris,
are you talking about the gas fuel vent line valve (see attachment link).
Hi woodtster,
is there another flap further down the fuel pipe after the metal flap right at the neck of the fuel pipe where the gas nozzle is inserted to fill gas?
//www.pcars.com/porsche_parts/shop.php/porsche/carrera-2/4/turbo-996-/fuel/air-intake-system/gas-fuel-vent-line-valve/p_136147.html
BV
Old Mar 4, 2013 | 04:37 PM
  #37
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Status?
Old Mar 5, 2013 | 09:52 AM
  #38
Question Problem is still there!
The problem that I have is still there. However, I can pump fuel in, by very slowly at the same time pressing the pressure release switch at the neck of the fuel neck insert. It would take about 10 minute to fill the tank from low to full.
In a few month when I have more time, probably I will replace the fuel pump inside the gas tank to see if that will solve the problem.
I'll report back after I've done it.
If anybody has different suggestion. Please let me know. Thanks
BV
Old Mar 5, 2013 | 10:50 AM
  #39
mmm635's Avatar
mmm635 is infamous around these partsmmm635 is infamous around these parts
BV
Did you follow the advice from duane996tt? I ask because this is exactly what I would tell you to replace from my experience. This is a common problem that occurs when people keep filling the tank when the nozzle shuts off automatically repeatedly, just to get that extra little gas in the tank. Well, this ruins the charcoal canister over time and will cause this exact problem that you experience.
Fuel pump has nothing to do with it - this is a passive problem while the car is shut off, and you car is running well I presume when it does run.
Old Mar 5, 2013 | 12:35 PM
  #40
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
The fuel pump trick
Depending on the brand of pump, manufacturer of the fuel, reseller of the gasoline, the time of day and many other factors.. your Porsche will either like drinking or not.
Seriously, this is a problem that has gone unnoticed by Porsche and their complete crew of test drivers for the last ohh .... ten years or soo?? You are the first ever person that has problem with this. Seriously though.. turning the fuel nozzle 90 or 180 degrees, of course HOLDING IT MANUALLY .. might do the trick for you. It does for me. Int he end there are some brands of fuel and some gas stations you will avoid because people will look at you funny when yopu pumping gas with the nozzle in weird positions. Other pumps will always work. This is a Porsche option. You paid for it !
Old Mar 5, 2013 | 02:33 PM
  #41
mmm635
Thank you for reminding me about replacing the charcoal canister. I'll do that first to see if it would solve the problem. I assume it is located between the filler neck and the gas tank. Do you have any info on exactly where it is located?
hroussard,
I have try different nozzle positions and different gas stations. Nothing positive so far.
BV
Old Mar 5, 2013 | 03:18 PM
  #42
hroussard's Avatar
Did you check and see if perhaps your gas tank is collapsed. That would potentially restrict the flow of gas too. How many gallons of gas can you pump AT THE MAX??
Old Mar 5, 2013 | 03:27 PM
  #43
The tank is fine. I would be able to slowly pump in between 12 to 13+ gallons in 10 to 15 minutes.
BV
Old Mar 5, 2013 | 04:08 PM
  #44
hroussard's Avatar
BV
Have you tried to leave the ignition on when pumping gas or even - gasp - left the engine on??
Old Mar 5, 2013 | 04:13 PM
  #45
GCBC's Avatar
GCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond repute
This has happened in a few of my cars. I attribute it to the gas station pump itsself.
Some stations it doesn't do the automatic stop like your describing and some it does it constantly
