Dension 500s bt...
Old Oct 18, 2012 | 01:26 PM
motts's Avatar
motts has a spectacular aura aboutmotts has a spectacular aura aboutmotts has a spectacular aura about
Dension 500s bt...
Hi any tweaks on this unit to get better reception and sound from the phone? Also the ipod won't charge???
Thanks.
Old Oct 18, 2012 | 03:16 PM
wross996TT's Avatar
What firmware are you running? TMK current is 2.22. Check connections with the iPod (use compressed air to clean the connection points).
Old Oct 18, 2012 | 03:39 PM
motts's Avatar
Firmware on iPod or Dension? It's a new unit but I will use my newly purchased compressor.
Thanks.
Old Oct 18, 2012 | 04:36 PM
wross996TT's Avatar
firmware on the dension.
Old Oct 18, 2012 | 05:39 PM
motts's Avatar
Would you know if its the same as the 500 procedure.
Thank you.
Old Oct 18, 2012 | 05:51 PM
wross996TT's Avatar
Thank you.
Sorry don't understand your question. Go to the Dension site for instructions to check firmware and update said firmware.
Old Oct 18, 2012 | 05:58 PM
motts's Avatar
I will do that thanks.
Old Oct 18, 2012 | 08:43 PM
motts's Avatar
Did the firmware and unplugged everything and it worked. After about 30 min it's setup and thumbs up to Dension everything works. Swiped 120 songs for 1200. Cd changer is on the shelf and it's a nice clean install. Unfortunately I don't have the phone button.
Thank you.
Old Oct 19, 2012 | 08:44 AM
wross996TT's Avatar
Thank you.
My pleasure...glad it worked.
Old Jul 9, 2013 | 10:24 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
just installed the Dension Gateway 500S (non-BT) into my PCM 2.0 996 porsche MOST system. Every works fine, but I get an error saying "CD Changer Unavailable" when i turn the car on. Has anyone else had this issue?
Old Jul 9, 2013 | 11:26 AM
motts's Avatar
I did a firmware update and everything seems to be working. But the Bluetooth is kind of waist.
Old Jul 9, 2013 | 01:32 PM
split's Avatar
I'll give it a shot.. why'd you buy the bluetooth model if you don't have the phone buttons?
Old Jul 9, 2013 | 01:37 PM
motts's Avatar
You can use your phone to answer and then switch.
Mark @ AIM Performance
46
Aug 29, 2021 12:57 PM
Perkman87
Nov 19, 2015 05:31 PM
alpha motoring
Oct 2, 2015 12:04 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
