GT2 Slave Conversion Opinion
Old Mar 19, 2013 | 10:49 PM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
I just picked up my car from the shop after a few things, a GT2 slave conversion was among them.
If you haven't done it, do it.
Enough said.
Old Mar 19, 2013 | 10:57 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
I agree.
Old Mar 19, 2013 | 11:07 PM
XwalkerX's Avatar
XwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud ofXwalkerX has much to be proud of
since i havent done a whole lot of research into it...
explain the pros over stock and cost plz
Old Mar 19, 2013 | 11:23 PM
dhahlen's Avatar
pros -
-no more hydraulic clutch assist
-no more failing stock slave
-no pentosin through slave
-feel the engagement point
-engagement point doesn't move
-clutch is very consistent
cons -
-some people want the grandma clutch pedal, by this i mean the pedal effort is increased since the hydraulic assist is removed. Took me 2 minutes to get used to it, even in stop and go traffic it's fine. However, this has bothered some.
Old Mar 20, 2013 | 12:22 AM
FineProperty's Avatar
FineProperty is infamous around these parts
I'll do a search as well, but briefly, how much is involved over just changing my currently broken accumulator?
Old Mar 20, 2013 | 12:37 AM
dhahlen's Avatar
Some people sell the brackets to do the conversion yourself, but you'll also need the lines and some additional parts.
This is the kit I used: http://sharkwerks.com/products.php?pid=162
The board has a DIY somewhere, I've seen it.
It's worth the extra cost, I am really happy with it.
Old Mar 20, 2013 | 02:55 AM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
I JUST finished installing the EVOMS kit! wow it was a pretty hard install despite the DIY guides out there. I haven't tried it yet since i'd wake the neighborhood up but can't wait to try it in the morning.
Old Mar 20, 2013 | 08:13 AM
irish100p's Avatar
irish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to all
Well I was fairly on the fence on this one, but I am definitely not on the fence now. I don't care about increased pedal pressure, but this grandma clutch feel has to go. Thanks for the info.
Old Mar 20, 2013 | 10:33 AM
SSMugen's Avatar
HOLY $HIT!! best mod yet!! I have a Clutchmasters Stage 3 Clutch which was about to get the boot b/c of a very high engagement point and either on/off which would lead to a lot of over-revs. With the EVOMS GT2 Slave kit the clutch is now very predictable and engages in the middle like stock!
If anyone is on the fence about this... DO IT!! I went w/ the EVOMS kit b/c it is came with all the correct parts such as the hydraulic line which was came with a predrilled fitting right into the slave making it a simple screw and you are done. No mickey mousing around with used lines or stock lines that don't give enough slack. It also comes w/ the correct screws and fittings to block off the unused lines.
I did this in my garage and it took me about 12 hours vs. the quoted 7-8 hours but I learned a lot, went slow, quadruple checked and did some cleaning while I was under there.
Good luck!
- David
Old Mar 20, 2013 | 11:19 AM
pwdrhound's Avatar
Great mod. I had this done last fall. After much discussion with a number of folks, instead of using the bracket method, I opted to have the conversion done just like on a factory GT2 using all OEM GT2 parts with the GT2 slave installed on the drivers side factory location of the gearbox. We also removed all the old hydraulic lines from the car instead of blocking them off and leaving them in place. One of the best mods you can do.
Old Mar 20, 2013 | 11:21 AM
sharkster's Avatar
yep it's really a great mod. Makes clutch engagement more natural and easier. Plus you never have to deal with that flawed hydraulic assist system which always fails after 3 years....
Old Mar 20, 2013 | 01:11 PM
bbywu's Avatar
There is a very good DIY that a member put together here:
https://www.6speedonline.com/forums/...rsion-diy.html
It's for a 997TT, but very similar to a 996.
Old Mar 20, 2013 | 03:24 PM
wross996TT's Avatar
Yep...I must agree...great mod! Nuf said!
Old Mar 20, 2013 | 03:28 PM
aggk's Avatar
aggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud ofaggk has much to be proud of
If all you're looking for is a better clutch engagement feel why not first try removing the clutch assist spring?
Old Mar 20, 2013 | 03:30 PM
wross996TT's Avatar
Se post 4 above...
