996TT 6pots calipers/Upgrade to 380mm disc
#31
Why changing the master brake cylinder? Im am running 380 mm ceramic discs and 6-piston-calipers on the front and 350/4 on the the rear, just like the full big ceramic package of the 997.1 turbo on my 996 turbo.
The 996 master brake cylinder just works fine. Before it had to feed 4 larger pistons and now 6 smaller ones. You won't notice the difference in the pedal.
The difference of that brake on a lighter car you will notice for sure
Porsche actually went a step further on the 997GT2/3 cars by again reducing the 380 front caliper piston bores by another 30% compared to those on the 997TT 380 calipers. This further firmed up the brake pedal while at the same time giving the GT cars more rear brake bias. The difference in simply running the GT calipers vs. the TT calipers is very noticeable. Yes, the smaller stock 996 master will work with the 997 brakes but it is not ideal. The brake definitely feel better with the larger master, and even better with the 997 cam driven vacuum assist pump.
#32
[url=https://flic.kr/p/dWTmLi]
#33
You for sure did way more testing than I did - good work. In my application there is no downside by keeping the 996 stock on the master brake cylinder. The brakes do bite hard and pedal travel is no issue. Not saying that it can't be better - it always can.
#34
i guess the one i have just went up in value like a gt2!!
#35
Ok if you aren't making any more can you tell me the length of line you used?
#36
The length is the same as whatever the factory 10/10 line is. I don't remember the exact number I measured but I wanna say it was about 14". I could be persuaded to make another batch of these but I'd have to have a commitment for 6 of them for it to be worth my time. It was a bit of a pain to make to correct bends along with the flares. I have a high end flaring tool that makes perfect bubble flares but it's fairly time consuming.
#37
I've still got one custom line from John laying around here and still deciding to install or not. Anyone running this without PSM disabled and without any Problems? I think nearly all who got the new brake master and custom line installed, got PSM failure, but maybe not up to date.....
#38
#39
Can't really say what the issue is with PSM when running the larger master. We think that is has to do with the brake light switch. When you run the larger master the brakes will move more fluid per given pedal stroke. As such, the ABS/PSM module will sense deceleration prior to the brake switch activating. When that happens, you get a PSM fault. I believe it's a simple matter of readjusting the switch to close a bit sooner.
Strange thing here was the fact that when I had hot brakes (= already increased system pressure, like 2nd or 3rd stint at track) the ABS/PSM disconnection was instant at first touch of the brake pedal. At street driving or day's first stint no problems. We all know the feeling when you can't completely trust your brakes.
There's a diffecence with pedal feel indeed.
#40
........ The one thing you will need to be careful of is the selection of wheels if you run the 380mm set up as only a hand full of 18" wheels will clear those brakes. My track 18x9 front wheel will clear the 380 calipers with about 3/16" to spare but they are manufactured to work with the 380 set up. The silver 5 spoke wheels are 19x9/12 and the grey track wheels are 18x9/12 in the pics below. Hope that helps.
Ronny-
03-14-2018 11:21 PM
b4stiTTS
06-19-2016 12:16 PM
Dr Chill
07-06-2007 04:09 PM
