Help! Unknown leaking fluid question
Old Apr 21, 2013 | 11:24 AM
911turborookie's Avatar
911turborookie is infamous around these parts
During a down shift (tiptronic) 85mph or so on the parkway car felt great but engine cab starting and pouring grey smoke- thought oh boy....Pulled over immediately - All over the back area of the car was a clear sticky fluid sprayed all over exterior of the rear and under the engine dripping after letting the car idle. Can't seam to figure out were the fluid is coming from or figure out what it is???? Had the car towed to prevent further damage- fluid has no color or smell-engine runs perfect no noises - thinking a gasket or hose maybe fitting ...but what is clear and does not smell??
Anyone ever have this problem or know what it could be??? Any help is greatly appreciated.
2002 996 turbo tiptronic
Old Apr 21, 2013 | 11:51 AM
Tim941NYC's Avatar
Only clear orderless fluid that I know of that could be in your car is water..
Old Apr 21, 2013 | 11:57 AM
Water from?
Old Apr 21, 2013 | 03:00 PM
Anyone have any ideas where this fluid might be coming from?
Old Apr 21, 2013 | 03:36 PM
raineycd's Avatar
Probably blew a coolant hose or pipe. Sounds like same scenario that happened to mine.
Check your coolant - or did you get any lights on the dash?
Old Apr 21, 2013 | 06:35 PM
No lights on dash- just clear fluids all over ... Literally blew fluids on everyone behind me as I was driving.... Just can't understand why it's clear fluid and no distinct smell.... Weird
Old Apr 21, 2013 | 07:11 PM
ttboost's Avatar
Probably blew a coolant hose up front. Plenty of them to let go...that's the only way it could get in the car if you are moving...
Old Apr 21, 2013 | 07:23 PM
Meant all
Over cars "driving" behind me... Not in the car :-/
Old Apr 23, 2013 | 06:48 AM
So this is what was leaking... A coolant pipe
They wanted me to drop the engine to repair- fortunately this coolant pipe is the most accessible out of all- I'm having them reglue it... A lot cheaper than dropping engine.... It lasted 11 years from the manufacture so I won't have to worry about this particular one... I'd rather drop the engine when I absolutely need to for others that are not accessible...Anyone else experience this??? Ruined my cannonball run the day it happen.... LoL
Old Apr 23, 2013 | 08:02 AM
996turbo4365's Avatar
996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all
Thanks for the update ....nice that you did not need to drop the engine
nlakind
Nov 6, 2015 10:15 AM
LiquidElephant
Aug 27, 2015 06:17 PM
markski@markskituning
Aug 24, 2015 10:07 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
