Head Gasket Porsche 996TT comparison! The same or different
Old May 6, 2013 | 11:27 AM
thepomak's Avatar
thepomak is infamous around these parts
Hi,
I have a question is the
Cometic Head Gasket .040''/102MM Porsche 996TT
http://www.burtonpower.com/cometic-head-gasket-040-102mm-porsche-996tt-3-6l-01-04-c4492-040.html
the same like
EVO 996TT Head Gasket Kit
http://www.sharkwerks.com/products.php?pid=73
I think the description is the same although the EVO describes it in more detail or could you tell me the difference.
The difference is only the price which is huge or not
I hope you can help.
Old May 6, 2013 | 10:33 PM
Tim941NYC's Avatar
First what size motor? 3.6? I had no luck with cometic.. I use head gaskets right out of the dealer. Factory!!!
Old May 7, 2013 | 09:33 AM
thepomak's Avatar
yes it's a 3,6 and I have also problems with cometic... could you give the name from your dealer/ Factory you trust and 've bought the head gaskets or maybe the store link?
I hope you can help me
Best regards
Old May 9, 2013 | 10:45 AM
unvmy996's Avatar
It's a stock Porsche head gasket , any dealer should be able to get them
Old May 10, 2013 | 10:26 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
I have a New set if you want
Old May 11, 2013 | 01:13 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I have used Ruf and had good luck with them.
Old May 11, 2013 | 04:15 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
I faced head gaskets twice with comtic and
Raceware head studs !
Now i switched to evoms head studs , and stock head gaskets ! Much much better
Old Sep 23, 2013 | 02:04 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Why do you find this combo much better?
Please explain.
Cheers,
Nick.
Old Sep 23, 2013 | 02:31 AM
layinback's Avatar
layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !
Stock head gasket fo sho.
btw, ysfg35 what's up with raceware head studs?
Old Sep 23, 2013 | 07:29 AM
i use raceware studs. they work well for me.
#TeamAIM
Old Sep 23, 2013 | 12:45 PM
ysfg35's Avatar
Please explain.
Cheers,
Nick.
Hello there , i was running cometic gaskets and raceware head studs , the bolts these studs run are thin and abit small , i faced head gaskets issues 2 times in 2 months !
So i switched to Oringing the sleeves with copper Oring and stock OEM gaskets plus evoms headstuds !!
Evoms head studs were much more quality , i used them with OEM bolts which were perfect !
As running Oring sleeves , i saw alot of guys here running these setups for high moded porsches , some use steel oring with special gaskets , and some use copper oring on the sleeves with OEM gaskets which am running !
Running very very good and did not face any issues !!
Just my thought
Old Sep 23, 2013 | 12:57 PM
rmc1148's Avatar
I have not done the 996tt head gasket deal yet but have done 944 928 and Audis use only oem.
Old Sep 23, 2013 | 02:31 PM
layinback's Avatar
Me too.
Old Sep 23, 2013 | 06:27 PM
racewear and cometic are good.. I would take it to 1.8 bar.. I think a few guys here were pushing more then that and or running with low octane combo... everything has its limits...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
joseph_number1
Jul 19, 2018 05:45 PM
BlackMarketRacing
Dec 8, 2015 01:49 PM
vr6tee
Aug 29, 2015 03:52 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
