tried to turn on the engine - failure light appeared
Old Jul 17, 2013 | 10:48 AM
adelino's Avatar
adelino is infamous around these parts
Hi,
Yesterday i went for a drive.
Parked the car and after 2 hours in the coffee shop, i tried to go back home.
Entered the car, key on the ignition, turned it and nothing appened, except the engine failure light.
Tried it again... and nothing.
It has battery, but the stater engine doesn´t turn.
Can someone help??
Thanks,
Adelino
Old Jul 17, 2013 | 10:51 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
Check the battery. Really check the battery. Either take it to a parts store or have a friend/colleague/family member/trusted clergyman try to start the car while testing the voltage with a multimeter.
Old Jul 17, 2013 | 01:13 PM
adelino's Avatar
HI,
i´ve disconected and reconected the battery.
It was charged and the onboard multimeter, showed it was charged...
So... still without solutions!!
anyone else helps???
Old Jul 17, 2013 | 01:29 PM
sinKing's Avatar
Originally Posted by adelino
HI,
Not good enough. Test it using one of the two options I gave you. You don't want to rule out the battery, the simplest and most common reason for a car not starting, without properly testing it.
Old Jul 17, 2013 | 03:26 PM
ttboost's Avatar
Brake switch or neutral safety switch failure?
Old Jul 17, 2013 | 04:32 PM
croach's Avatar
croach is infamous around these parts
HI,
You need to just replace the battery. I fully charged mine. Same result. No start. Went to advance auto. Got another battery. And bam. Problem solved. Get a new Battery. You will need one eventually.
Old Jul 17, 2013 | 10:53 PM
Hi,
Can someone help??
Thanks,
Adelino
did you do any mods to the car just recently? new tune?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 18, 2013 | 03:07 AM
adelino's Avatar
I've recently tried to connect a rosstech cable vag113 just to see how it works.i couldn't make any software connection, so i quited. The car started after trying that and i drove for 200miles with a few stps on the way.nothing strange. Picked the car from my garage the other night, went for a coffee and when trying to go back home...just didn't start...
Old Jul 18, 2013 | 03:57 AM
ttboost's Avatar
Could be ignition switch failure also...battery's usually don't just quit..you would've had a sign...
Old Jul 18, 2013 | 11:35 AM
adelino's Avatar
Hi,
my OPD says that he can´t read the DME and it is toasted.
can this be true??
And yes, i´ve tried to connect a ross tech vag113 cable few days before this happened..
please help
Old Jul 18, 2013 | 11:41 AM
ttboost's Avatar
Anyone check Fuse for DME? Row C, Position 1? Do you have a "check engine" light when you turn key on?
Old Jul 18, 2013 | 01:08 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Yes he said it lights up when he turns the key. Wow that is not good DME is expensive.
Old Jul 18, 2013 | 01:26 PM
ttboost's Avatar
Wasn't sure if that's what he meant by "engine failure light". I didn't have an "engine failure light" in my 996 turbo.
I just recently had this exact problem in my RS6...turned out to be neutral safety switch...which incidently CANNOT just be jumped out or bypassed...screwed until you get another one...fortunately it's cheap...
Old Jul 18, 2013 | 02:05 PM
adelino's Avatar
it´s a manual, so i don´t think it has a neutro safety switch...
someone... help!!!
Old Jul 18, 2013 | 02:25 PM
ttboost's Avatar
someone... help!!!
Do you have to have your clutch pedal in to start your car? If so, that is your "neutral safety switch". There should be a switch on the "up" side for the cruise control and a switch on the "down" side for the neutral safety switch.
