Failure of engine compartment blower fan.
Old Aug 7, 2005 | 06:34 PM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
I've been getting this message "Failure of engine compartment blower fan" from time to time, however, the fan is working. Whenever I parked the car, I can hear the fan kicked-in, etc. At the time when I received the message, my temperature was just a little bit above the 180 mark. I do lived in the area where temperature is above 100 degrees plus.
It can't be the thermostat, fuse, or ???
Any ideas on what/where to look for?
Thanks in advance.
Old Aug 7, 2005 | 08:32 PM
PorschePhd's Avatar
Bet you have a GT2 tail don't ya?
Old Aug 7, 2005 | 09:28 PM
RT7's Avatar
RT7
Yeap, GT2 tail. Is this normal?
TT Surgeon's Avatar
How does that cause it?
Old Aug 7, 2005 | 10:48 PM
californian's Avatar
californian is infamous around these parts
Mine has a MAShaw GT2 wing and does the exact same thing. Annoying as hell. Just recently I started getting the warning and the little red idiot light at the top of the temp gauge has started going off even though the needle is at 187 degrees. I've hooked up my computer to the car and checked that the temp gauge was reading correctly. It was.
I do have one question for the group. Especially the guys with the stock turbo wing. When the auxiliary fan kick on in your cars does the fan suck air into, or blow air out of the engine compartment?
Old Aug 8, 2005 | 02:20 AM
RT7's Avatar
RT7
Isn't it suppose to blow hot air out? Sounds like a common thing with GT2 wing.
Old Aug 8, 2005 | 10:42 AM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
On stock turbo tail fan draws air from topside and blows it down past the motor.
Old Aug 8, 2005 | 06:56 PM
That's what I thought! Those of us with GT2 after market wings have the exact opposite. Stephen what do you think? Could this be causing the problem. As a final logic check how about some of you real GT2 owners weighing in. When your aux fan kicks on does the fan draw air in or out of the engine compartment? Thanks all.
Does anyone know if I simply reverse the wires to the fan will that cause the fan to run in the opposite direction?
Old Aug 9, 2005 | 12:45 AM
oak's Avatar
oak
it's simple to reverse the polarity if you want the fan to switch rotation direction.
nlakind
Nov 6, 2015 10:15 AM
saline
Oct 7, 2015 07:29 AM
turbotuner20v
Sep 11, 2015 12:02 PM
ECS Tuning - VW
Aug 27, 2015 08:30 AM
bobolouie
Aug 26, 2015 12:02 PM
