Protomotive/IPD 996TT_3.8L Alpha28 851whp/857Ft lb
Old Sep 24, 2013 | 04:04 PM
orbelo's Avatar
orbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud of
We ran the cars on the Dyno Jet this past saturday at European Auto Source(EAS) in Anaheim CA with the ShiftSector crew. My car with the Protomotive tune, 3.8L Mahle upgrade, complete push through setup and IPD's latest dimpled custom Y-Pip and TB with meth injection made the following numbers with 1/2 tank of 91 Octane, 5 gallon MS109 mix along with 100% methanol spray.
PSI 29.04
851Whp & 857Ft lb
See dyno graph attached... Oh and yes it can be done with Alpha28's!!!
Build thread:
https://www.6speedonline.com/forums/...0-lbstorq.html
Old Sep 24, 2013 | 04:37 PM
WILLIAMP's Avatar
WILLIAMP is infamous around these parts
Wow.
Jealous.
Old Sep 24, 2013 | 05:37 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
thats some powa!
Old Sep 24, 2013 | 06:00 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Congrats! That torque must come on like crazy. Would you share the specs on the drivetrain? (RWD?, LSD, clutch, gear specs, etc)
Old Sep 24, 2013 | 06:10 PM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
thats 900+crank hp !very impressive but sceptical !is that proto mafless ?
Old Sep 24, 2013 | 06:34 PM
orbelo's Avatar
Actually almost 1000 crank 15% reduction for rwhp. Whats the skepticism on the mafless tune? Works flawlessly for me for over a year now since I switched from maf.
Old Sep 24, 2013 | 06:41 PM
orbelo's Avatar
Drivetrain, OS Giken LSD, RWD conversion, clutch master 850 Series dual disc setup.. gear spec 1-3 gear 997GT2 4-6 steel synchros 996tt gearing. 997 ssk, Evoms billet shifter link...
Old Sep 24, 2013 | 06:44 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Wow congrats Orbell!
I'm running proto mafless and its flawless as well. I had MAF issues where it would stall out the car when revs dropped and no more after the mafless flash.
- David
Old Sep 24, 2013 | 07:02 PM
zblake's Avatar
zblake is infamous around these partszblake is infamous around these parts
Wow, must be like getting shot out of a cannon. Great looking too. Well done sir. Well done!
Old Sep 24, 2013 | 07:42 PM
mtlsp's Avatar
wait a minute you said a 1000 hp on a28 !!! i have seen a3076 on e85 put down 780whp at 28psi... what's the secret?
Old Sep 24, 2013 | 07:50 PM
orbelo's Avatar
No corner cut and mix of right components. My full build thread is at the beginning of this thread, feel free to inspect.
Todd K, after seeming the dyno said I had wheel spin per the graph, so in all fairness probably be able to put down some more power if traction wasn't an issue.
Old Sep 24, 2013 | 07:54 PM
2swoosh's Avatar
2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future
congrats! that is impressive
Old Sep 24, 2013 | 07:56 PM
orbelo's Avatar
Thanks guys... Really appreciate it.
Old Sep 24, 2013 | 08:19 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Wow, very impressive numbers with your setup. Great job man!!!
Old Sep 24, 2013 | 10:32 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Holy crap! Gotta be scary fast!!
Btw, do I spot GMR in the background ?
