Gremlins - hesitation going uphill
Old Nov 26, 2013 | 08:24 PM
Gixxed_Spyder's Avatar
Gixxed_Spyder is infamous around these parts
Question Gremlins - hesitation going uphill
Help!
Ok so I've been trying to figure this out for awhile, and the dealer hasn't been able to pinpoint anything - here's what's happening:
Cruising in 4th gear, start going up a steep hill about an 1/8 mile long pulling about .1 to .2 bar. There is some noticeable hesitation when trying to hold a steady speed. If I hammer it, it takes off without any problems. I've got a durametric, but I'm not sure what to log to try and figure out what is causing this. Note, this doesn't happen while cruising on a flat surface. For some reason, I feel like its an intermittent vacuum leak - or could be something in the fuel system.
recently replaced plugs and coilpacks
EPL tune for 3 years, this just started happening about 8 months ago
no codes are thrown
Where should I start? Smoke test? Fuel Pressure test at an angle???
Old Nov 26, 2013 | 08:38 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Same crap with me but when data logging select all cylinder miss fires and see if your miss firing i had a small leak that caused this in the back of the intake which took over 4 hours to get too.
Old Nov 26, 2013 | 08:43 PM
How'd you end up finding the leak? Smoke test?
Old Nov 26, 2013 | 08:48 PM
996tt550hp's Avatar
I listened to these guys on here and i kept on saying no way it can be and bam did a smoke and pressure test heck a smoke test found it that's how bad it was lol. It was in a bad place in the back also diverter hose was leaking so try that first its the cheapest.
Old Nov 26, 2013 | 08:52 PM
Did you do the smoke test yourself? Any tips?
Old Nov 26, 2013 | 09:17 PM
996tt550hp's Avatar
No went to a shop to get it done. It's pretty easy just take your intake air box out and the smoker will block it then check for smoke around the engine bay.
Old Nov 28, 2013 | 07:00 PM
Pressure test from the turbos to 20 psi ... must hold for 30 seconds...
do this and you will find your issue
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 28, 2013 | 07:03 PM
996tt550hp's Avatar
Hey marski u said u have a kit for the pressue test? For sale
Old Nov 28, 2013 | 11:32 PM
What's the best way to get to the turbos? Do I need to block the other turbo off when I do this test?
Bobbyfali
Jul 31, 2017 01:28 AM
Glasgo
Nov 30, 2015 02:37 PM
COBB Tuning
Nov 3, 2015 08:39 AM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
drizute
Sep 27, 2015 05:57 AM
