Need recommendation for trans fluid for 996tt
Old May 11, 2014 | 08:59 AM
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
Originally Posted by pwdrhound
I changed my gearbox fluid 5x this year. I do it every 6 track days using Mobil1 Delvac 75w90. The stuff comes out pretty filthy especially if you have an LSD because of all the particulates that shed off the clutches. Delvac is standard fill in the Cup cars / GT2/3 which all of which use an LSD. I buy Delvac in 5 gallon pails at $150 which works out to $30 per change since you need 1 gallon. For a stock 996TT with an open diff the OEM Mobilube PTX or Shell Transaxle work well as they are slightly thinner than the Delvac and will flow a touch better in freezing temps. You can get the Shell from your dealer in 1Liter bottles for about $25 each. Most gearbox builders will tell you to change at 15K mile intervals for street driven cars.
I just changed my stock fluid out to the Mobil 1 Delvac 75w90. When the tranny is cold, grabbing 1st gear is pretty hard to do. After 10-15min of driving it is easier and throughout my 1hr commute, it shifts very nicely.
Is this normal for the Delvac?
Old May 11, 2014 | 09:11 AM
pwdrhound's Avatar
Yes, normal
Old May 11, 2014 | 10:16 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I went with Redline as recommended in this thread
No issues that I can think of, including 1st gear when cold.
Old May 11, 2014 | 10:35 AM
evil 996tt's Avatar
I have no issues but when it is cold here(Chicago), 1st gear is hard to get until the fluid warms up a bit. Also, when I say hard, I mean just a little notchy feeling. It does go in gear, just not as easy as with the stock fluid.
Feelgood MD
Mar 24, 2016 09:35 AM
MrMiggy
Sep 14, 2015 02:18 PM
oo7
Sep 10, 2015 08:08 AM
sparks
Sep 8, 2015 03:03 PM
ship it
Sep 7, 2015 10:49 AM
