Alignment settings
Old May 10, 2014 | 10:38 AM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Alignment settings
I'm looking for road course and high speed settings. What should I tell tell the shop to set at or head towards?
Old May 10, 2014 | 10:46 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
Subscribed
Old May 10, 2014 | 11:56 AM
wross996TT's Avatar
Is your suspension stock?
Old May 10, 2014 | 11:57 AM
Whereitsat's Avatar
H&R springs and eibach sways. That's it.
Old May 10, 2014 | 12:06 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
track settings will be very different from high speed 'street' settings, or do you mean high-speed track setup?
Old May 10, 2014 | 12:22 PM
Whereitsat's Avatar
Track setting.
Old May 10, 2014 | 12:28 PM
993GT's Avatar
Kussmaul settings:
Front Camber - 2.5 degrees
Front toe 2 mins per side
Caster 8 degrees -0+.5
Rear Camber -2.4 degrees
Rear Toe 14 mins per side -0+2. 28-32 mins total
Loaded ride height 112mm front, 130 mm rear
Old May 10, 2014 | 01:01 PM
Whereitsat's Avatar
Thank you
Old May 10, 2014 | 02:37 PM
pwdrhound's Avatar
Here's my track alignment, with fuel and driver:
Front camber: -3.25deg
Front toe: +0.02' (+0.04' total)
Rear camber: -2.42deg
Rear toe: +0.15' (+0.30' total)
Ride height
Front: 96mm
Rear: 124mm (119mm when transposed to 996TT subframe)
Old May 10, 2014 | 03:24 PM
Whereitsat's Avatar
Sweet!
Old May 11, 2014 | 06:01 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Good info
Old May 11, 2014 | 06:18 AM
Whereitsat's Avatar
Pwdrhound, does she track true at high speeds (135+)?
Old May 11, 2014 | 08:45 AM
IhazA996TT's Avatar
IhazA996TT is a glorious beacon of lightIhazA996TT is a glorious beacon of lightIhazA996TT is a glorious beacon of lightIhazA996TT is a glorious beacon of lightIhazA996TT is a glorious beacon of lightIhazA996TT is a glorious beacon of light
Subscribed
Looking for a similar setup for my car. High speed street stability with a trackable aspect.
Car is on PSS9 with a gt3 rear sway.
Old May 11, 2014 | 09:21 AM
pwdrhound's Avatar
Yes. Tracks very true but everything on the suspension is monoball except the dog bones. This keeps everything locked down and true especially under load.
Old May 11, 2014 | 11:51 AM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Front:
-3.0° camber
1/32 toe in (each side)
Rear:
-2.7° camber
Excellent (almost even) tire wear on the track
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
