DIY In Tank Fuel Pump Upgrade. (pic heavy)
Thats what im talking about dude, ive been looking for that for ages.
I was thinking about putting a couple of HKS BOV.s on the stock Y pipe, I reckon I have room.
The reason to use larger diameter pipe is because every pipe has friction from the walls, the longer the run the more the friction. Thus, longer runs needs larger diameter inorder to maintain the same flow as a shorter smaller diameter pipe.
Honestly much of this is spitwad engineering. If you really want to determine the effect short of a ton of math why not simply plumb a mechanical vac guage into the pipe just an inch or so prior to the turbo inlet? If you see significant pressure drop the turbo is choking - simple as that. For some real fun do this on a stock intake setup
Oval tubing, pressed tubing, silicone hose, lots of options. As for filter positioning - the stock airbox gets fresh air from outside but it's a long run. Fender wells get lots of air from around the ducting. Upper ducts are something I really want to retain but I know someone doing some temp testing and I may do some of that myself. I'm going to be running size large intercoolers on a mildish setup so it'll be interesting.
Mods, any chance we could split this into yet another intake discussion? lol
That's my plan as well but I also know someone testing without top ducts since apparently most of the airflow is drawn not forced through the IC. We shall see, I prefer to keep ducts for sure!
thats the guys running 6" cores and no room for ducts. hard to imagine its drawn not forced since theres no pressure on the ducting while sitting at a standstill. i can lay my hand at the opening and theres no draw at all. only way i could imagine a draw would be to install a puller fan on the bottom side of the cores
sorry never took any pics
Hmm. I can't visualize the placement. I was going to place mine above the ICs...seems like the best for fitment of 3" pipes/filters.
Also, I would imagine there's a low pressure area near the exit of the IC duct....hence pulling air through the fender intake and through the IC.
I'm no engineer either.
