Drilling and taping tranmission case for GT2 hydraulics and have a question????
Old Feb 13, 2014 | 10:43 AM
Tim941NYC's Avatar
I run no assist spring at all.
Old Feb 13, 2014 | 11:24 AM
32krazy!'s Avatar
i tried that and my cruise control would kick off on every bump in the road. using a lighter spring from home depot i reinstalled the spring and the cruise works fine now but the pedal is very stiff (like my big rig!) so i ordered the gt2 spring and ill try that.
Old Feb 13, 2014 | 12:31 PM
Tim941NYC's Avatar
Say what?? We have cruise control?
Old Feb 13, 2014 | 12:37 PM
Slider's Avatar
Originally Posted by 32krazy!
heres everything needed for the conversion. i was able to find a p/s setup for 300$ but you can either plug the hyd lines or remove them and tap the reservoir and pump for plugs. its your choice
GT2 Slave…996 116 237 90 $130
GT2 Master…996 243 171 06 $65 996 423 171 06
GT2 Assist spring (you definitely want this, trust me)…996 423 081 18 $55
Brake fluid cap…996 355 119 01 $5
GT2 Hose…996 423 377 90 $105
GT2 Clutch fork…997 116 086 90 $180
GT2/Tip PS reservoir (optional, you can just plug the lid)…997 314 920 50 $480
GT2 PS pump (optional, just remove the coupler from the turbo pump)…996 314 050 01 $400 996 314 050 52
btw the prices have gone up since i did this
Correction noted. Here is my estimate using the latest prices from Pelican Parts and my local INDY:
Old Feb 13, 2014 | 12:50 PM
32krazy!'s Avatar
Attachment 333693
i wouldn't pay 1100$ for the p/s setup. search the boneyards for a tiptronic unit unit. same as a gt2 or simply plug off the lines and save the money. i did the labor myself and it wasn't hard at all. actually the hardest part is getting the master cylinder in under the dash. just no room for a pair of arms!
Old Feb 13, 2014 | 01:04 PM
Slider's Avatar
Yeah, I was thinking that looks pretty steep. The job is quite reasonable if you remove the power steering stuff.
Old Feb 13, 2014 | 01:07 PM
32krazy!'s Avatar
you can plug the lines back by the trans and only remove the p/s pump enough to remove the coupler
https://www.6speedonline.com/forums/...tructions.html
Old Feb 13, 2014 | 02:01 PM
Slider's Avatar
Excellent write-up! The search here really sucks because that thread didn't come up during my search for this info...
Old Feb 13, 2014 | 02:05 PM
pwdrhound's Avatar
I removed all the old hydraulic lines. There is no need for them. Why plug them? Toss them...
Old Feb 13, 2014 | 02:08 PM
32krazy!'s Avatar
with the engine in the car its a pain to get them out. plugging them makes it easier for those trying this and they can be removed down the road if the engine ever comes out.
by plugging them you don't have to drill and tap the p/s only need to remove the coupler. just easier for some. for me i removed everything lines pump and res and installed a gt2 setup
Old Feb 13, 2014 | 02:15 PM
pwdrhound's Avatar
Same here... I also have the proper GT2 assist spring. Clutch feels perfect.
Old Feb 13, 2014 | 03:57 PM
Tim941NYC's Avatar
You can easily get a 8mm brass plug made to seal the larger line and the other smaller steel line you can just cut and weld the line or get a plug made too or tap both and plug with npt plugs.. You just need to remove the coupler on the pump.
orbelo
Aug 30, 2015 12:26 PM
Zero911
Aug 24, 2015 06:51 PM
