O2 Sensor spacers - recommendations?
Old Mar 25, 2014 | 09:41 PM
dustent's Avatar
dustent is infamous around these parts
I just had a Techart exhaust system installed and my check engine light is now lit. From what I've read, it's fairly common to get an O2 CEL with this exhaust. What are folks using for O2 spacers? I'm assuming that'll help?
Old Mar 25, 2014 | 09:46 PM
johnspeed's Avatar
It must be 100 cell cats or catless system?
FVD and SpeedTech sells them to help with that problem.
Good Luck
Old Mar 26, 2014 | 06:25 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
think mine is from Vibrant. Milltek exhaust. No CEL but not sure if its needed anyway...
Old Mar 27, 2014 | 02:31 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Get a tune. They remove that regardless. Plus it's more fun.
Old Mar 27, 2014 | 02:35 PM
993GT's Avatar
not sure if OP is tuned or not, but I am(and am re-tuning with EPL). Simpler to pass emissions with a extended O2 than by bypassing the readiness code
Old Mar 27, 2014 | 04:31 PM
WaterNWheels's Avatar
WaterNWheels is infamous around these parts
How do the spacers affect the output of the O2 sensors? I'm considering doing the stock muffler mod that creates a short circuit through the muffler internally with the 2 inch cut out as described in the forums here but don't want to deal with the emissions repercussions. Would the spacers correct emissions failure after the muffler mod is performed? Like to understand the physics behind how the spacers are supposedly working.
Old Mar 27, 2014 | 05:02 PM
993GT's Avatar
the extenders keep the secondary O2's out of the exhaust stream and in a 'clean' air space. Not needed for muffler modifcations, only if removing or using certain high-flow catalytic converters.
I'm going to try removing them this year and see if I get a CEL...
Old May 10, 2018 | 04:46 AM
negb's Avatar
negb is infamous around these parts
https://www.fabspeed.com/universal-9...nverters-pair/
just can't understand how does this little cat get enough of the main exhaust flow to heat-up sufficiently for the cat to actually function ?and gases has to flow out through cat and here they end up into O2 sensor.....
Old May 10, 2018 | 12:19 PM
pwdrhound's Avatar
I'm running 3.5" catless bypass pipes and using the short FVD extenders as you can see on the 3rd rearmost oxygen sensor below. Works as advertised. No CEL and all readiness codes show as READY.
Old May 10, 2018 | 03:28 PM
negb's Avatar
Yours is not cheap extender, it is the same type 'minicat' as from Fabspeed
https://www.fvd.net/us-en/FVD111LAMS...r-minicat.html
I'm started thinking do I really need these minicats as I will have engine ECU custom tune up
Old May 23, 2018 | 11:18 AM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
x2. I tried the spacer route pre-tune; never lasted.
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
Rockinc1
Sep 30, 2015 06:44 PM
zoo
Sep 3, 2015 10:46 AM
WheelB
991 Turbo Vendor Classifieds
Sep 3, 2015 10:26 AM
