Eibach Springs
Old Sep 19, 2005 | 11:01 PM
WyattTT's Avatar
WyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud ofWyattTT has much to be proud of
Eibach Springs
How do the Eibachs compare to the rest? Input needed, Im new at the Turbo game.
Old Sep 20, 2005 | 04:50 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Eibach
= Techart for as much as I know and they are good !
Old Sep 20, 2005 | 11:07 PM
WyattTT's Avatar
Re: Eibach
Thanks.
I know eibach have their stamp on techart springs, so I am assuming they make them for techart.
Old Sep 21, 2005 | 04:43 PM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Are stock shocks OK to use with the Eibach springs? How is the ride?
Old Sep 21, 2005 | 04:46 PM
orijinal_poser's Avatar
orijinal_poser is infamous around these parts
if you're using higher spring rates than stock, i would definitely upgrade to aftermarket shocks. say koni or bilstein or something..... with higher spring rates, it will wear out your stock shocks very quick.
Old Sep 21, 2005 | 04:52 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Eibach makes a quality product.. And they are very consistent in there rates.
If you are just installing a lowering kit, then it is highly recommended that you upgrade the shock absorbers also.
For a little more money you might consider getting a coil over kit, you will most likely be happiest with that choice...
Either way I can help............
Old Sep 21, 2005 | 10:45 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
i'm running cargraphic springs with oem shocks. no problems and the shocks are still going strong after 7K miles with a total of 18K on the car.
i've heard awful things about the eibach on our cars. i would stick with cargraphic, techart, or HR.
eibach may have their stamp on the techart springs, but i bet the spring rate/materials are probably different.
Old Sep 21, 2005 | 11:02 PM
Member
Fabryce, I respect your opinion highly as you have a lot of track experience. But if the Eibach spring rates are not significantly more than stock and they do not lower enough to hit the bumpstops, shouldn't the stock shocks be up to the task for a street car? Personally, I think it is absurd to have coilovers unless you are tracking the car and this would necessitate corner weighing.
Old Sep 21, 2005 | 11:06 PM
Member
Glad to hear your oems are up to the task (so far!).
All the searching I've done shows that the Eibach/Techart are the more reliable springs and the H&R are the more troublesome ones.
Old Sep 21, 2005 | 11:47 PM
Ask marc from bertsmithmoto what he thinks of the eibachs
seriously, check out the cargraphics. i researched this to death before i made my purchase. stock shocks are fine. unless you're putting mega miles on your car over really bumpy roads, i wouldn't worry about it. my car rides great and the drop is perfect. i wouldn't have lowered it anymore with coilovers. the handling is much better than stock. i'm sure the coilovers handle even better, but i don't track my car.
Old Sep 22, 2005 | 06:41 PM
WyattTT's Avatar
Thanks for all the responses, exactly what I was lookin for. Ive been looking into this, but sales people are out for the buck, but you guys have the experience and your opinions.
silversrt
Jan 24, 2016 03:45 PM
DannyK
Ferrari
Nov 27, 2015 05:56 PM
4080
Oct 5, 2015 01:44 PM
Ronny-
Oct 1, 2015 10:40 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
