Build thread because why not
Old Sep 8, 2015 | 08:50 PM
  #196
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
Iam happy that she is running again , great work and I can't wait to run mine
Old Sep 10, 2015 | 05:40 PM
  #197
BLKMGK's Avatar
How much power is it making now and at what pressure? E85 correct?
Old Sep 10, 2015 | 09:52 PM
  #198
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Originally Posted by itguy
She's alive again on 12mm studs. With the boost leak fixed (ipd checkvalve, replaced with a billet piece), picked up close to 500 rpm of spool. Small changes to the tune, traction is worse now as the tip in is much harder so the tires spin, TC strategy will be revisited tomorrow.
We ended up machining 20 thow off the the sleeves to remove the oring grooves entirely, then dropped the cylinder case the same amount, and compensated with custom Evoms hellfire gaskets.
Want to thank John Bray @ Evoms for providing all of their bullet proof hardware needed to build a long lasting high powered flat 6.
My IPD check valve was leaking too Sean causing boost issues. The billet piece seams interesting. The damn check valve was throwing check engine light and couldn't figure out what was the issue.
By the way any stage 3 fuel systems in stock?
Old Sep 11, 2015 | 08:27 AM
  #199
irish100p's Avatar
irish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to all
Billet piece? Shoot me the details please.
Old Sep 11, 2015 | 08:49 AM
  #200
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
Great to hear Sean. I wonder where your compression really sits at the moment
Dzenno@PTF
Old Sep 11, 2015 | 01:57 PM
  #201
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Same power @25 as was at @30 before. Boost hitting 700 rpm sooner, very happy.
Old Sep 11, 2015 | 02:19 PM
  #202
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
You turned up the timing because of the bigger studs?
Old Sep 11, 2015 | 02:33 PM
  #203
itguy's Avatar
We had a -8 boost leak through the IPD check valve, replaced it with a billet cv, thats where the spool came from.
Old Sep 11, 2015 | 08:51 PM
  #204
Man the IPD check valve caused me a lot of drama. My alpha 3071's were spooling at around 5k lol I checked everything from headers thinking they were leaking to thinking turbos were bad etc and all along it was a cheap check valve that IPD uses.
Glad you figured it out man. I'm actually getting rid of the whole thing. Going custom intake after my shop tested it and said they saw no real benefit for my application.
I'll call you tomorrow regarding the fuel system Sean!
Old Sep 11, 2015 | 10:05 PM
  #205
itguy's Avatar
I changed mine out for this turd
Old Sep 13, 2015 | 04:06 PM
  #206
32krazy!'s Avatar
when we were talking i thought you just changed the check valve!! thats sweet
Old Sep 17, 2015 | 12:15 PM
  #207
ASDTANK's Avatar
ASDTANK is infamous around these parts
Holy machining **** batman that's a beautiful build.
Old Sep 17, 2015 | 01:04 PM
  #208
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
Good god.... That is amazing!
Old Sep 20, 2015 | 03:33 PM
  #209
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
Updates?
Saint Ari
Jan 17, 2022 09:22 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
justthebest
Sep 5, 2015 04:02 PM
TurboDragon
Sep 4, 2015 09:11 PM
