Build thread because why not
Old Feb 5, 2015 | 04:23 AM
  #91
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Machined these flanges from bar stock with the transition built in from the ports to pipe.
Just finished tacking them up.
Old Feb 6, 2015 | 06:42 PM
  #92
unvmy996's Avatar
damn they look pretty ,
Old Feb 6, 2015 | 07:02 PM
  #93
itguy's Avatar
Finished welding them up and started on these too
Old Feb 6, 2015 | 08:33 PM
  #94
BLKMGK's Avatar
Awwww yeah!
Old Feb 6, 2015 | 08:58 PM
  #95
itguy's Avatar
Can't catch a break, the POS tilton throw out bearing decided to fail and squirt fluid all over the place... Out comes the trans again....
Old Feb 6, 2015 | 11:17 PM
  #96
Not the slave ?
#TeamAIM
Old Feb 6, 2015 | 11:18 PM
  #97
itguy's Avatar
Originally Posted by prodigymb
Not the slave ?
Ya, thats what I mean, slave/tob one piece thing
Old Feb 7, 2015 | 10:43 AM
  #98
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
You Sir are a fabricating ANIMAL!!!! Wish I had skills like this, I wouldn't sleep making all sorts of none sense. Like a shop chair using piston rods welded together for its legs.....
I read your other thread about the clutch, if it requires dot 3/4, a GT2 hydraulic setup is in order. For your skills, once parts are sorted, it should take no time.
Keep going you are right there man!!!!
Old Feb 7, 2015 | 09:49 PM
  #99
turbodanny's Avatar
turbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond reputeturbodanny has a reputation beyond repute
Keep up the good work Sean, you're almost there brother.
Old Feb 8, 2015 | 09:25 PM
  #100
itguy's Avatar
Old Feb 8, 2015 | 09:40 PM
  #101
itguy's Avatar
https://www.youtube.com/watch?v=iT07...ature=youtu.be full speed
Old Feb 8, 2015 | 09:47 PM
  #102
BLKMGK's Avatar
Tailgaters beware!
Old Feb 9, 2015 | 03:30 AM
  #103
'02996ttx50's Avatar
yeah, that'll keep em off yer *** ha..
Old Feb 12, 2015 | 04:27 PM
  #104
turbodanny's Avatar
Dam!!!
Old Feb 15, 2015 | 06:11 PM
  #105
itguy's Avatar
making progress
As mentioned before, Sam sent us a set of his billet k16's for testing on a built motor. originally they lit so fast and hard they were jumping to almost 900wtq at 4200ish, we dialed back the boost by rpm and gear. Here is a 4th gear pull ramping to (1.7bar) 25psi by redline (7200)(black line is 1 bar wg spring). Stock manifolds, stock intercoolers and glorious E85 (e82 according to meter)
Remember we bumped compression to 10:1 (our dyno reads within a few % of the local MD500, these are legit numbers). The dip is boost controller DC changing, needs a little smoothing.
